gears
  • 2395 Views
Offline Flatlander
  • 45
gears
« on: July 25, 2012, 03:32:03 PM »
Can someone help me understand the gear process when i run larger tires?  I have 5:12 stock gears. i am running 33 inch tires.  My question is, which way do i have to go in gears to get closer to the factory?  Feeling a bit dumb here for asking.  Thanks
Re: gears
« Reply #1 on: July 25, 2012, 05:58:48 PM »
your wanting to go towards a 5:62 ratio.
Offline Flatlander
  • 45
Re: gears
« Reply #2 on: July 25, 2012, 06:05:08 PM »
Thanks.  i appreciate this.  Any idea what they might be found in that would fit in my stock diffs?
« Last Edit: July 25, 2012, 06:07:37 PM by Flatlander »
Re: gears
« Reply #3 on: July 25, 2012, 06:53:05 PM »
they are kinda hard to find and spendy   if you do find them, there are some for sale on this site but they come from a 1989 4 door with an eight valve 1.6 I think, if you go lower to like a 5.89 you will have to go to a ford nine in the rear or some kind of a dana, I think calmini still has the front ring and pinions.
Offline Bobzooki
  • 1754
  • Web Wheeler
Re: gears
« Reply #4 on: July 27, 2012, 08:53:32 AM »
Calmini USED to sell 5.83's  They work GREAT for 33's.  I had them on the Gnewt.
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline talonxracer
  • 1284
Re: gears
« Reply #5 on: July 27, 2012, 09:46:47 AM »
There are few options for a tracker/sidekick without swapping axles front and rear to Toys or dana units, would be to install an undertaker and run the much stronger 4.30 R&P's or go with a sammi TC with 6.5 gears.
There may be 5.71 R&P's available in the future, but when is the real question.........
Offline tuxblacray
  • 20
    • Tuxblacray Photos
Re: gears
« Reply #6 on: July 28, 2012, 02:57:14 AM »
This may help you in your gear quest. These are the ratios found by year in the different models. Nice to have if you are looking for 3rds from a Pick & Pull....
89    2dr 1.3L carb 5speed man. 5.625
89-95 2dr 1,6L TBI 5speed man. 5.125
89-95 2dr 1,6L TBI 3speed auto. 4.625
91      4dr 1.6L TBI 3speed auto. 4.625
91      4dr 1.6L TBI 5speed man. 5.375
92-98 4dr 1.6L MPFI 5speed man. 5.125
92-98 4dr 1.6L MPFI 3speed auto. 4.30
92-98 4dr 1.6L MPFI 4speed auto. 5.125
94-98 2dr 1.6L MPFI 5speed man. 5.125
94-98 2dr 1.6L MPFI 3speed auto. 4.30
94-98 2dr 1.6L MPFI 4speed auto. 5.125
96-98 X90 1.6L MPFI auto or man. 4.625
4.625 gears have an 8/37 tooth count
4.30 gears have an 10/43 tooth count
5.125 gears have an 8/41 tooth count
5.375 gears have an 8/43 tooth count
5.625 gears have an 8/45 tooth count
