Suzuki Samurai G13A engine - SOLD -
  • 0 Replies
  • 1478 Views
Offline mverley
  • 652
  • 20
  • SPACE JUNK
« on: July 25, 2012, 06:08:53 PM »
This engine has been sold; thanks for the interest!
I am selling a used 1.3L G13A 1324cc engine out of a Suzuki Samurai. This engine is a direct bolt in for any year Samurai.
I pulled it last weekend from a friend's samurai for a motor swap; not sure of the miles on it.
The engine runs fine and was in use as a daily driver up until last week; however it will need a new head gasket. It never overheated, but for some reason it developed a small external coolant leak (needed to put a cup or two of water in it for every few hundred miles of driving). You can see a small section on the side of the block where the coolant was seeping out from around the head gasket. It was not burning coolant internally, or allowing coolant and oil to mix. The bottom end should be OK; I didn't pull the pan to inspect bearings/etc., but it wasn't making any funny noises.
I did a compression check on the engine a few months ago when my friend purchased the Samurai and it checked out good; I don't remember the exact numbers but they were all very close to each other and within the acceptable range.
It is currently sitting on an engine stand in my shop. It comes with everything that is bolted to it in the picture; alternator, water pump, etc. No intake or exhaust manifolds, or distributor.
This is located in Seaside, OR but I may be able to deliver to Portland, if I'm already making the trip. I have a trip planned on Friday, 7/27/12.
Price is $200, cash only.
PM me or post in this thread with any questions.  Thanks!
Matt
« Last Edit: July 30, 2012, 07:11:06 PM by sewerzuk »
My rig is a fusion of Jazz and Funk; I call it JUNK
