suspension for a tube sidekick
  • 2581 Views
Offline spooln1
« on: July 27, 2012, 12:57:14 PM »
I am in the process of buying a 4 door sidekick that I will cut the whole thing apart and make a tube body out of. Making it look almost Identical to a rzr4. I am planning on leaving the stock suspension with sway bars removed. (this will be an offroad only vehicle) my question is I am taking a vehicle that weighs 2700lbs and hopefully taking it to the 2000lb mark or below. I am planning on driving this about like a rzr so suspension is key. What can I do to make the suspension softer(which springs and shocks) and get more travel out of the factory setup up?  Thanks
Re: suspension for a tube sidekick
« Reply #1 on: July 27, 2012, 04:11:08 PM »
Take a look at what a lot of us have done to the Zukiworld Challenge racers.  Longer links and nice long shocks are a requirement.  I would also switch to 14 or 16" springs as well, running 220 14" on the back of Project Trouble made a world of difference.
For faster off racing you will want to look at increasing your up travel as well.  But your going to be hard pressed to keep up with a RZR.  You only have 6.5" of travel on the front end with the strut suspension, you won't be able to keep up with the 14" they are pushing.
Offline spooln1
« Reply #2 on: July 28, 2012, 06:27:20 AM »
I know I'm not going to be real competitive I just want to be able to hold my own with them, since I can't justify 15 grand on one right now. Where do I get these springs and shocks you're talking about?
Offline kreator
  • 634
  • 15
« Reply #3 on: July 28, 2012, 10:22:41 AM »
longer arms ,better shocks change the wheel base , I built the new fox based struts on mine and made a big differance.
Offline spooln1
« Reply #4 on: August 02, 2012, 02:07:04 PM »
I would like to see about purchasing the shocks and lower strut brackets from you. If you could give me a call at 618-384-7680 of email me at calebcoston|removethispart|@att.net with a price shipped to 62821 that would be awesome! thanks
  • 6603
  • 69
« Reply #5 on: August 02, 2012, 06:17:03 PM »
FWIW: I don't think you'll be able to keep up with a current Rzr. Maybe if you spent like 15 grand. :)
