Fuel pump hoses
  • 3247 Views
Offline Serious
  • 57
Fuel pump hoses
« on: July 30, 2012, 05:11:49 PM »
Could some one please tell me where the bottom small hose goes on the fuel pump. I think it's a vent or needs to go some where.....? but where. Pictures of your engine compartments would be awsome. Thank you
Re: Fuel pump hoses
« Reply #1 on: August 01, 2012, 01:23:27 PM »
If you jump over to ACK's Faq you can get a FSM (Factory Service Manual).  You can also pick it up from suzukiinfo.com.  Those are probably your best bet.
Offline Serious
  • 57
Re: Fuel pump hoses
« Reply #2 on: August 01, 2012, 06:40:21 PM »
Thank you!
Re: Fuel pump hoses
« Reply #3 on: August 03, 2012, 09:08:59 AM »
If you post some pictures we can probably find things for you.  Some of us are hard of memory when it comes to fuel lines after re-routing them a few times.  :)
Offline Serious
  • 57
Re: Fuel pump hoses
« Reply #4 on: August 05, 2012, 10:12:35 PM »
Fule pump picture
Offline 02CalTaco
  • 196
Re: Fuel pump hoses
« Reply #5 on: August 09, 2012, 10:25:24 PM »
That is where oil will leak out if the pump is bad. It doesnt go anywhere, mine dosnt even have a hose on it.
Offline Serious
  • 57
Re: Fuel pump hoses
« Reply #6 on: August 13, 2012, 12:17:03 PM »
Thank You x 10
Re: Fuel pump hoses
« Reply #7 on: August 14, 2012, 08:25:23 AM »
Fule pump picture
Do not put a hose on it.  You want to know ASAP, if it starts leaking oil.  If it does start leaking oil, you need to change the fuel pump ASAP, and probably change your engine oil and filter.  When oil starts leaking out of the hose, it means the diaphragm in the pump is ruptured and gas can get into the oil....hence why the oil and filter should be changed, along with the pump.
Offline Serious
  • 57
Re: Fuel pump hoses
« Reply #8 on: August 19, 2012, 12:31:05 AM »
Great information. Hose off. Thank you
