Lets talk - Oils
  • 23 Replies
  • 5460 Views
Offline Mike71
  • 1449
Lets talk - Oils
« on: April 06, 2004, 12:06:33 PM »
my tracker 8v has like 85k miles...should i switch to synth oil?? or stay with the reg stuff?
also i was reading something about switching to synth in the rear diff?? anyone have any more info on that?
also since my car has 85k miles what if anyhting should i do to the tranny/transfer case oils?? i have a 5spd
any info on that would be great since i know next to nothing if not nothing about most of those..i know how to change my own oil thats about it =)
i also know how to get off a pesky filter with a screw driver =) lol
Offline Maiden Hell
  • 1650
  • MAIDEN HELL!
    • My Space
Re: Lets talk - Oils
« Reply #1 on: April 06, 2004, 12:37:48 PM »
I run Mobil 1 5W30 (full synthetic).  I have found that it makes my engine run smoother, quieter and cooler.  I changed to Mobil 1 around 80000 miles. I've been using it ever since.
I changed the oils in my diffs and t-case about a year ago.  Used standard Castol Gear Oil.
I have an AT and had that changed a few years ago.  I'll probably do it again this winter or next summer.  Used regular Dexron III AT fluid, although next time I want to switch to a full synthetic fluid.  Same will go for the diffs/t-case.
Offline Mike71
  • 1449
« Reply #2 on: April 06, 2004, 01:01:40 PM »
now i know what kinda fluid is in an AT trans..but whats in a MT..is it the same...also wheres the dip stick in my car for the MT  :o yah yah i know i should know that lol
Offline Samurai_Hamster
  • 28
    • Samurai Hamster
« Reply #3 on: April 06, 2004, 02:04:08 PM »
Mobil 1 for me since about 4K on the clock. Runs like a champ.
Or a monkey with its ass on fire.  Depends on how good the gas is that day. ;D
Offline Maiden Hell
  • 1650
  • MAIDEN HELL!
    • My Space
« Reply #4 on: April 06, 2004, 02:36:07 PM »
DO NOT USE AT FLUID IN A MANUAL TRANSMISSION.  It's different stuff.  I believe that MT fluid is more or less all the same, so just pick a reputable brand and use it.
I don't know if a MT Track/Kick has the same layout as an AT one...but the dipstick for the AT is right beside the distributor cap, just to the left of it looking straight ahead from the front to the back.
(I WANT MY DIGITAL CAMERA ALREADY!!)
Offline Mike71
  • 1449
« Reply #5 on: April 06, 2004, 03:24:07 PM »
lol i have a digi cam..but no where to post pics :(
ill look for the dipstick tommorow..i want to make sure i keep up on these things now that i am keeping the car
this is my first car...and my rents dont help me with it at all..so it really is all mine  ;D
Offline DSHornet
  • 250
  • Logs and Sidekicks don't mix well at 60 MPH.
« Reply #6 on: April 06, 2004, 03:58:23 PM »
My suggestions:
Oil - I have used Valvoline Max Life 10W-30 with a new filter at 3K mile intervals for a couple of years now. I'm satisfied, especially since the oil cured a slow leak or two on the engine.
Automatic transmission fluid - New filter and Dexron III every two years or so.
Manual transmission, t-case, differentials - Name brand gear lube 75W-90 or 80W-90. Using expensive synthetic in the t-case and transmission will make for easier shifting in cold weather, assuming it gets cold where you are.
Paw-paw Don, y'all
Paw-paw Don, y'all
.Late '94 Sidekick 1.6 ragtop, slightly modified.
Favorite saying: "One need never apologize for exercising the Golden Rule."
« Reply #7 on: April 06, 2004, 09:58:13 PM »
I have seen many posts about this over the past year and I dont get the spend twice as much on oil thing. I have 3 Zuks all get the cheap stuff at what ever quick lube I happen to stop at, and inbetween the 4-5000 miles I usually wait to change it again, it gets the cheep stuff from the gas station.
The result:
89 Kick Purchased with 60,000 miles, now has over 200,000 miles and still running strong (never rebuilt)
97 Tracker Purchased with 90,000 miles, Drove it to 130,000 miles and now it a parts truck for the 89 and motor is still running great.(never rebuilt)
98 X-90  Bought with around 60,000 miles, now has 120,000 still running great (my 1000 miles a week commute vehicle)(never rebuilt)
Usually I believe in the "you get what you pay for" and I know there have been test out there to "Proove" the synthetics are better, but I'm sticking with the cheep stuff.
« Last Edit: April 06, 2004, 09:59:23 PM by Zukipilot »
Offline kf4zgz
  • 10
  • Lizooki- the upwardly mobile Zook
    • Amateur Radio- And my Zuk
« Reply #8 on: April 06, 2004, 10:29:07 PM »
Regular oils- Guess what ? they're are only 5 or 6 big oil ccompanies......now look at all the brand names. All that oil comed from the same people/places. The only big difference from the big'uns is what they add. I'd suggest staying away from the ones with a hi parrafin content. Wax will plug up anything. Other than that....cheep-0 oil-o fer me!
Synthetics- ain't got a clue. Never used any. I worked on circle track race cars for 10 years and never saw an oil related engine problem using regular oil.
Matt
Weber, CJs in rear,antique Dessert Steel shackles, ruf, homemade ML-style shackles in front,all me-fabbed-no kits, still spua---------- Yeah, I can be really dangerous when I get to thinkin'!
« Reply #9 on: April 06, 2004, 11:22:47 PM »
Matt
What's that :-/ (parrafin) An additive to the oil ???
Offline jerryp58
  • 449
« Reply #10 on: April 07, 2004, 12:55:16 AM »
I'd stay with the dino-oil at this point.  Use the viscosity the owner's manual recommends (mine is 5w-30) and change it every 3-4 thousand miles.
I thought I had read that dino-gear oil should be used in the diffs, but synthetic is OK or even good for the trans & transfer case.
Your MT should have a drain/fill plug like the t-case and diffs.
FWIW, if your '89 has drain & fill plugs on the diffs like my '90, you may want to make sure you can get the fill plug loose before you remove the drain plug.  I didn't and of course I couldn't get the fill plug off so I had to fill it from the drain plug; that was fun ::)
Jerry
« Reply #11 on: April 07, 2004, 03:14:20 AM »
Having worked in parts stores and shops most my life, Here are my recomendations. If you take care of your rig, dont drive to hard,and change the oil every2-3 k regular oil will work great. Now knowing zooki guys I know we all drive hard. In a motor with low miles(under60k) I would use full synthetic. You can switch to synthetic before that but I wouldnt recomend to after. Synthetic oil can find its way through smaller gaps than regular oil, so it may start leaking. It also offers much better protection, and less breakdown. For engines with around 80k + i really like the extended life stuff. Like the maxlife. It will help stop oil leaks and burning. For the transmissions I use full synthetic again. It makes the tranny's shift smoother, run cooler and quieter. I also use it for the t-case and differentials. Now if you have a rig that makes alot of drivetrain noise or has alot of miles try lucas oil stabilizer in the tranny,t-case,and diffs. Just use it straight out of the bottle. That stuff is amazing. I also like to use the lucas in diffs with lockers as it seems to help with the noise and random snapping. Any how all this info is just my experience and opinion. beleive me I have tried most of them.
Oh and one more thing I forgot. If you use Penzoil, dont use anything but Penzoil. The parafin base does'nt mix very well with petroluem base oils. That's how you get build up. Its not a bad oil,just dont mix it.
And one other thing about synthetics. Dont mix them with regular oil. All your doing is wasting it. It doesnt offer you anymore protection when it mixxed.
« Last Edit: April 07, 2004, 03:15:12 AM by bigzook »
Offline Zuki One
  • 441
    • ZUKI - PICS
« Reply #12 on: April 07, 2004, 04:39:24 AM »
Now on a fresh motor how long do you wait to change the oil and how long do you wait before puutin the synthetic in there? iheard at least a 1000 to make sure all the bearings have seated?but i am not quite sure :-/
"Sooo What shop built your rig?"hahahahhahahah    www.cardomain.com/memberpage/607888/1
« Reply #13 on: April 07, 2004, 06:32:19 AM »
Thank you I did forget that part. I cant remember exactly how long but you definatley want to wait a bit.
Offline mavapa
  • What, no personalized text?
« Reply #14 on: April 07, 2004, 07:59:55 AM »
Use whatever oil you want to. Synthetics are good and actually required in some cars, but if you change regularly, regular old oil will do fine for our vehicles. Most manufacturers say you can use synthetics, but probably for warranty reasons they say not to extend the oil change intervals.
The manual transmission won't have a dipstick. You usually check the lube level by taking off the filler plug and sticking your finger in. If you can feel lube, you're OK. But since you're down there, why don't you go ahead and drain and refill? A lot of people like synthetics for the transmission, transfer case and differentials. Check your manual to see what weight is recommended. As noted, do not use automatic transmission fluid unless it is recommended (as it is in a few rare cases).
While you're at it, replace the brake fluid. Very few people do that, but most manufacturers recommend it at about 2 year intervals. If you have never drained old brake fluid out, it usually looks like used motor oil - not a good thing.
