Front locking hubs for 2002 Escudo
  • 3005 Views
Offline ottavs
  • 02 Grand Escudo V6 24 valve 2.7L automatic
« on: July 31, 2012, 11:15:24 AM »
WARN only certifies their front locking hubs for up to 2001 Escudo/Vitara.  Anyone know if they're OK for 2002?  What's the difference between 2001 and 2002?
« Last Edit: July 31, 2012, 11:32:40 AM by ottavs »
Offline nprecon
  • 2318
  • 52
  • ONWARD... through the fog!
Re: Front locking hubs for 2002 Escudo
« Reply #1 on: July 31, 2012, 11:33:30 AM »
I am running a set of Warn manual hubs on my 2002 Chevrolet Tracker and have for about 10,000 miles to date.
« Reply #2 on: July 31, 2012, 12:00:06 PM »
A word of caution - asking the wrong question can get you all sorts of incorrect information.
A 2002 Escudo would be an SQ series chassis, similar to a Vitara/Grand Vitara or a Tracker, but if what you have is a 2002 Grand Escudo, that's a JA series chassis, equivalent to an XL-7, and there are some differences.
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #3 on: July 31, 2012, 04:23:13 PM »
Isn't the front suspension the same on the XL7?  Every part I've ever seen for it specs the same Tracker/Vitara/Escudo/GV/GE/XL7 except for the springs?
« Reply #4 on: July 31, 2012, 06:02:39 PM »
There are differences in the front axle freewheel mechanisms between the JA & SQ series - I don't know all of them, but I know that they exist - I believe that the freewheel hubs that the OP asked about will interchange, but I'm not 100% certain.
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #5 on: July 31, 2012, 06:10:11 PM »
I know members on here have put manual hubs on XL7's before.
We are talking all 99-05 body style here, right?
Offline nprecon
  • 2318
  • 52
« Reply #6 on: August 01, 2012, 01:13:28 PM »
"A word of caution - asking the wrong question can get you all sorts of incorrect information."
A valid point.
Offline ottavs
« Reply #7 on: August 04, 2012, 12:19:16 AM »
All  very interesting, but still no clear answer.  Any idea of how to find out for sure?  thanks -- Ottavs
« Reply #8 on: August 04, 2012, 04:27:08 AM »
There's really only one way - bolt it on yourself - do be aware however, that, your Escudo (or Grand Escudo) most likely has a pneumatic freewheel clutch built in to the front differential, so the only advantage of bolting on freewheel hubs is reduced wear on the CV joints - since the driveline has already been disconnected there is no significant gain in fuel efficiency (if that's what you're looking for).
The point I was trying to make earlier was that few of us are familiar with the Escudos & Grand Escudos, and whilst we may be able to tell you what works on a Vitara or Grand Vitara, unless we know what your vehicle is equivalent to (and we still don't, because you've asked about an Escudo, and your avatar suggests you have a Grand Escudo), the answers we can provide may not be applicable.
These forums contain a truly amazing amount of collective knowledge, much of it gained from one individual or another, attempting to do something - like in your case, fitting free-wheeling front hubs to an Escudo - by someone looking at a part and thinking "this looks like it should fit" - the disconnect in this case comes from the fact that you are introducing a new and unknown quantity - an Escudo, which as I have said few of us will have seen.
It's also worth pointing out that there are quite a few JDM Escudos & Grand Escudos that have been exported as used cars and there ARE what I will describe as undocumented differences between the JDM models & the export models, which can make the job of finding out what fits your car truly a matter of trying it yourself.
Good luck.
« Last Edit: August 04, 2012, 04:33:19 AM by fordem »
