2L VITARA REAR AXLE!?
  • 10 Replies
  • 5007 Views
Offline Fredo
  • 416
  • Heavy music and Suzuki 4x4!
« on: April 06, 2004, 04:34:54 AM »
Do you think that i can fit this Kick HD Axle shafts
This 5.83:1 R&P
And this clamini LSD
In a 2000 vitara 2 doors rear housing or i will need to swap for a complete sidekick housing???
Thanx
Fredo
« Last Edit: April 06, 2004, 04:37:13 AM by Fredo »
Proud member of the C.A.B.L (coalition against body-lifting) 2002 GV
Re: 2L VITARA REAR AXLE!?
« Reply #1 on: April 06, 2004, 04:42:18 AM »
I dont know about the Limited slip and the gears but I think they would work. I have a locker and the gears that were in my 89 housing in a XL-7 housing in my anvil. When I originally spoke to Steve about the heavy duty shafts he said that you had to use them with the early year Kick Drums but the hosing on the 97 axle was fine. I dont know if the rear axles or brake size changed from 97 to 2000 or not.
Offline Samurai_Hamster
  • 28
  • 87 Octane knocker of a motor.
    • Samurai Hamster
« Reply #2 on: April 06, 2004, 06:28:21 AM »
man if the LSD would fit in myrig, I would buy it.
The Zuke is on its way out.  Getting a vehicle that will behave and be supported by the dealer.
Offline Fredo
  • 416
« Reply #3 on: April 06, 2004, 08:29:31 AM »
  • 28
    • Samurai Hamster
« Reply #4 on: April 06, 2004, 02:07:14 PM »
Why no 2002?  Did the rear ends change?  Are they referring to the bolts that hold the pumpkin to the housing?
Offline Charlie
  • 77
  • I love YaBB 1G - SP1!
« Reply #5 on: April 06, 2004, 09:22:20 PM »
Hi
Later models are 3 inches wider than the Sidekicks so I’m not sure those axles will fit. I believe your diff ratio is 4.625 (well maybe) so swapping in 5.12 ratios might be enough.
Regards Charlie
Offline sarmeier
  • 43
« Reply #6 on: April 07, 2004, 01:57:06 AM »
In 2001 or 2002 the rear axels are longer, at least the right (pass) side than the earlier years.  Just had replace a broken one on my 2002.
Also, at the same year model the rear carrier was redsigned and bcame smaller with a smaller diameter ring gear.  I just installed an ARB in the rear and discover this change the hard way.  Had to get a third member from a 1998 or earlier for the ARB to fit trhough the ring gear.  The best place for fitment information I found was Hawk.  I lot of folks think but don't really know, they do.
Offline Fredo
  • 416
« Reply #7 on: April 07, 2004, 04:29:59 AM »
Hi
Regards Charlie
Stock R&P on a 2 doors vitara with manual tranny is 4.875:1 and if i put 5.12:1 is enough for...
26"(stock tires) X 5.125(new R&P) / 4.875(stock R&P) = ................ONLY turn 27.34" tires :-/
Calmini put 5.83:1 R&P and lsd on the vitara extreme!
26"(stock tires) x 5.83(newR&P) / 4.875(stock R&P)
=....................31.1" it's that i want, 31" tires!!!
For the axles your probably right. I will mesure this on father's 99tracker tonight.
Fredo
Offline Charlie
  • 77
« Reply #8 on: April 07, 2004, 06:54:36 PM »
Are you running 215 65 16 tyres, these are 27 inch.26 inch sounds a bit small.
Charlie
Offline Fredo
  • 416
« Reply #9 on: April 08, 2004, 04:25:46 AM »
OK now with 27" tires...
27"(stock tires) X 5.125(new R&P) / 4.875(stock R&P) = ................ONLY turn 28.38" tires
and with5.83:1 gears...
27"(stock tires) X 5.83(new R&P) / 4.875(stock R&P) = ................you can turn 32.28" tires  ;D
and your speedo are right!
Fredo
Offline Yankee Tim
  • 431
  • Who says a GV is a grocery getter?
    • Yankee Off-Road
« Reply #10 on: April 10, 2004, 01:36:26 AM »
Fredo
I have 31's on my Auto GV.  Stock R&P was 4.88, and I swapped in 5.12's.  Works, but the 5.83's would have made it correct.
Yankee Tim
