steering slip joint????
  • 2031 Views
Offline track_this
  • 332
« on: April 08, 2004, 05:41:09 PM »
Is this the style of steering shaft that will not require an extention, in other words be able to slide out when you put on a body lift??
calmini 3 inch sus. lift
rear lockright
31" kumho m/t's
Offline 87BlackSami
  • 191
  • http://www.quic kvwbug.4wdriver .com/
    • http://www.quickvwbug.4wdriver
Re: steering slip joint????
« Reply #1 on: April 09, 2004, 02:07:13 AM »
Looks like it would work to me. You'll know better after you do the body lift. Take the shaft apart and make sure you have atleast an inch or more still inside the shaft.
locked,5.8:1 Tcase, 5.12's, 35x12.5Xterrain's, 4" BDS L/O, Ford towers, 5-8" shackles w/reverse, tracbar, Yota P/S, diffs capped, skidplates, onboard air, fabbed bumpers & shafts, Herculined, airhorns
Offline 1bigtracker
  • 3409
« Reply #2 on: April 09, 2004, 07:45:01 AM »
mine IS diffenet than that one and i DID an extention.
stu
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #3 on: April 09, 2004, 02:46:22 PM »
Yes
32 MTR's Warn 8000i
Offline track_this
  • 332
« Reply #4 on: April 09, 2004, 05:38:18 PM »
good deal just bought it for 5 bucks. thanks i was hoping it was the one that had the slip in it. thanks yall
rear lockright
31" kumho m/t's
