How fast should a 1.6 EFI 8v be?
  • 1946 Views
« on: August 06, 2012, 12:45:11 PM »
Hi guys,
I recently got a sami with 1.6 EFI 8v swapped in. History unknown unfortunately.
Just did a tune-up - plugs, wires, 02 sensor, Accel Coil, seafom - the basics.
With some help from guys on here, finally got it started...
It runs quite well 1-3 gears pretty peppy actually, but once you hit 4th, she falls on her face...no power, 5th is a rare occurence. Tops out at about 50-55mph.
It has 31s and SPOA, I don't believe it's been re-geared.
Is it that necessary to re-gear for just 31s? Is there anything I should look at?  I've never driven a sami with this motor swapped in before, so I am not sure what to. compare it to.
With the condition of the motor unknown, I'm probably doing a leak down test this weekend and check the timing.
I have no intentions of driving this thing at 70 or 80mph, but I'd like to know that it could get there!
Thanks!
Re: How fast should a 1.6 EFI 8v be?
« Reply #1 on: August 06, 2012, 01:28:36 PM »
I would say it needs regeared.  4.62s are a popular option with 31s.
Timing check, compression check and leakdown test are all good ideas.  The last two will give you a good idea on what kind of condition the engine is in.
« Reply #2 on: August 06, 2012, 01:57:20 PM »
Thanks for your response, and thanks for the help in my previous thread...I felt like an idiot, I wasn't very clear...
So 4.62s are popular for 31s, I don't plan on going any larger, as it sits this is just a decent little trail rig. SPOA and 31s.
Definitely doing those tests this weekend!
Do you have any experience with a Torquer cam? Header recommendation? Is it worth spending the extra money going Thorley vs others like Pacesetter?
« Reply #3 on: August 06, 2012, 03:10:29 PM »
I put a cam, header and high flow exhaust on a 1.6 8V sidekick I had years ago.  I didn't really see any difference....at least not enough to warrant the cost of it all.  Others may have different opinions.
