front out drive play
  • 17 Replies
  • 3932 Views
Offline standog
  • 111
« on: April 07, 2004, 04:47:10 AM »
Should the passenger side Half shaft have some play where it enters the pumpkin (the green cylinder part)? Hope this makes some kind of sense. Everything drives and shifts fine. It is on my 03 Vitara.
Thanks
Clay
Offline idaholwb
  • 772
Re: front out drive play
« Reply #1 on: April 07, 2004, 04:57:20 AM »
 Is it up/down-front/back play, or in and out play?
I wouldn't think that it should have any play there at all.
Might not be a bad idea to take it to the dealer to have them check it out.
97 Sport
265/70-16s
2" lift
2.0 swap
« Reply #2 on: April 07, 2004, 05:20:11 AM »
Sounds like the clip on the end of the axle is week or not there. It should sit snug to the case. Have you replaced the axle? If so, some of the rebuilds from Autozone Advance, etc... dont have the ring, so you have to pull it off of your broken axle.
« Last Edit: April 07, 2004, 05:20:33 AM by Zukipilot »
Offline standog
  • 111
« Reply #3 on: April 07, 2004, 05:21:38 AM »
it is in and out play. If you grab the shaft and move it there is no play. Just at the green piece. It does not feel like the whole axel is moving.
Clay
« Last Edit: April 07, 2004, 05:22:56 AM by standog »
« Reply #4 on: April 07, 2004, 05:35:27 AM »
When you move it look and see if the flat part of the flange that sits up against the housing is pulling away from the housing, that is what the clip is restraining.
Offline standog
  • 111
« Reply #5 on: April 07, 2004, 06:17:28 AM »
That is exactly where it is moving. Where is the clip? I pulled the axel when I put my coil spacer in. I pulled the clip out on the hub side but did nothing with the innner. How hard is it to replace. I plan on wheeling this weekend.
Thanks
Clay
« Reply #6 on: April 07, 2004, 06:41:45 AM »
There is a small ring on the end of the inner stub shaft (that slides into the housing) it is slightly larger tha than the shaft so when the shaft is pushed in it compresses untill it's cleared the sidegears, then it pops out to hold it in place. Let me look on izook and see if I have a pic of one. Back in a minute.
« Reply #7 on: April 07, 2004, 06:47:26 AM »
Sorry dude, I could not find a pick of the passenger side half shaft. Any one else have one?
Offline standog
  • 111
« Reply #8 on: April 07, 2004, 09:30:05 AM »
So I need to pull the shaft back out and install a new spring or just fix the one that is there? Will I be able to wheel this weekend or will I screw up the shaft?
Thanks.
Clay
« Reply #9 on: April 07, 2004, 10:36:59 PM »
IF it is sliding out much you may snap the splines off of the inner stub shaft (did it before, forgot to put the retainer on :P) I would definately drop that axle and check it before wheeling it. It sucks to pull it apart again but it;s better that traeing doen the whole axle housing to get broke axle parts out. Not to mention if it does not say against the seal and you get in any water it will fill up the housing with water.
« Last Edit: April 07, 2004, 10:37:13 PM by Zukipilot »
Offline jagular7
  • 1026
  • Jagular7
« Reply #10 on: April 08, 2004, 12:54:57 PM »
Don't forget some pics to show the 'Drama' of the front axle..... :-* :-*
Lenexa, KS
Offline standog
  • 111
« Reply #11 on: April 08, 2004, 01:01:11 PM »
I checked it agian today and there is about 1/16 of play. I never took the whole axel out when I did the spacer lift. I am going to crawl under a new one and see if it moves in the morning. If it is missing the clip then it has been that way for quite a long time with some serios wheeling being done. Lets hope for the best. Sided note got the RRO spacers on the back finaley and it looks more even with the front. not much of an overall lift about 1inch but every inch counts.
Thanks
Clay
« Reply #12 on: April 08, 2004, 02:50:16 PM »
If you still need a pick of the right axle I'll be right back with one. Any other pics needed?
« Reply #13 on: April 08, 2004, 02:58:15 PM »
Hows this?
« Last Edit: April 08, 2004, 03:53:11 PM by trickker »
Offline standog
  • 111
« Reply #14 on: April 08, 2004, 10:08:11 PM »
GOOD new's. I just check a brand new one on the dealer lot and it has the same amount of in and out movement as mine.
Clay.
« Last Edit: April 08, 2004, 10:58:36 PM by standog »
