What to use to clean soft top vinyl windows?
  • 3888 Views
Offline 144man
  • 85
« on: August 08, 2012, 03:55:03 PM »
My Sammi spends its nights parked on a busy street.  My rampage top is only a little over a year old, but the windows are getting to the point where they are un-cleanable.  Suggestions welcomed.
Re: What to use to clean soft top vinyl windows?
« Reply #1 on: August 08, 2012, 06:30:05 PM »
I use Plexus.  I wipe the dirt off the windows with a wet microfiber cloth first.  Then use Plexus and another microfiber cloth to clean/polish the windows.
« Reply #2 on: August 10, 2012, 03:09:03 PM »
I'm about to attack mine with T-Cut, my biggest problem is that the vinyl has curled and gone hard.
« Last Edit: August 10, 2012, 03:12:12 PM by Rhinoman »
Offline RACER X
  • 383
  • zuki or die!
« Reply #3 on: August 15, 2012, 08:10:54 PM »
if they are scratched you can get some vynal window cleaner from a boat uphostery shop
works greatl
98 kick
« Reply #4 on: August 17, 2012, 05:51:38 PM »
A while back I read on a Zuki form that lemon pledge works ...never tried it though
Offline tuxblacray
  • 20
    • Tuxblacray Photos
« Reply #5 on: August 18, 2012, 02:30:54 PM »
Lemon Pledge or similar is good to clean vinyl seats and your plastic dash. Armour All or similiar tire shine products will work great to help blend out the scuffs scratches you might have on your Rampage windows.
Use it on a Microfiber towel and store the towel in a zip lock bag when your done. Save it to be used on windows only so it won't accumulate dirt that might be heavier and be more abrasive to your windows.
Once you wipe down you windows with the tire cleaner gentle polish buff them back out with another clean microfiber towel.
You will like the results...        Tux...  8)
« Last Edit: August 18, 2012, 02:32:35 PM by tuxblacray »
Offline Cheeto
  • 55
« Reply #6 on: September 06, 2012, 10:50:17 PM »
My factory top windows were pretty hazy. Figuring I had nothing to lose, I used a headlight polishing kit on mine. Worked good for as bad as mine were but obviously you'll have to decide for yourself. It may leave slight swirl marks.
« Reply #7 on: September 07, 2012, 07:20:28 AM »
Meguiars PlastX
