Rebuild the 1.3 or move up to a 1.6
  • 10 Replies
  • 3713 Views
Offline GO_OUTSIDE!
  • 182
  • Sammy Jack
« on: August 13, 2012, 09:59:02 AM »
I just spent the past 3 weeks working on my first samurai. http://www.zukiworld.com/forum/build-diaries-how-to-diy/saving-an-87-samurai-from-the-wrecker-budget-daily-driver-plus-trails-build/15/
Today I took her to work and along with the smell of bad jetting (too lean I think), the truck is slowing down traffic. She pulls strong off the line but stops making power around 50mph. I am running 4.91 gears and 31" allterrains. It has a Tri Y header and new full exhaust. The PO replaced the stock airfilter with one of those cone type filters.
5th gear is only available down hill.
Whats a guy gotta do to earn some respect around here?
Offline ecoast
  • 509
  • 8
    • East Coast Canvas
Re: Rebuild the 1.3 or move up to a 1.6
« Reply #1 on: August 13, 2012, 10:21:13 AM »
read the last part of your thread
sounds rich, but even when tuned 1.3 is anemic
the axle gears help, but lower t case gears affect 2hi in samurai and you will benefit (you will do this even if you swap to 1.6; eventually)
play with this to see where you want/need to be:
http://www.lepayne.com/gears.html
But 1.6 FI is the answer to your question anyways. ;)..
Offline GO_OUTSIDE!
  • 182
  • Sammy Jack
« Reply #2 on: August 13, 2012, 12:11:44 PM »
Im thinking lean from the way it smells, but Ill check the plugs tonight. I havent found a guide for tuning the stock carb yet, any idea where I should be looking?
The idle is screaming fast, that could be another contributing factor.
The 4.91 gears are Tcase gears, Lowrange claims 18% reduction of high gear.
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #3 on: August 14, 2012, 03:48:35 PM »
Check out the '88 Samurai Factory service manual at Ack's FAQ (see link in signature, below).
do a search for fsm.
Ack
Offline GO_OUTSIDE!
  • 182
  • Sammy Jack
« Reply #4 on: August 15, 2012, 10:11:57 AM »
I downloaded a FSM from suzukiinfo, awesome manual, I forgot how bad Haynes manuals are.
I am heavily leaning towards a 1.6L upgrade. How can I be sure Im getting a good engine before I go through the effort of putting it in?
Offline ecoast
  • 509
  • 8
    • East Coast Canvas
« Reply #5 on: August 15, 2012, 10:31:29 AM »
buy it from a running donor or respected board member/vendor
try aftermarket4x4.com; tell him I sent you; he is a friend...
Offline tombstone
  • 212
« Reply #6 on: August 21, 2012, 03:47:06 PM »
Thats a hard choice,I see Rocky Road sells a rebuild kit for around $250!!
Offline mverley
  • 652
  • 20
  • SPACE JUNK
« Reply #7 on: August 30, 2012, 05:24:50 PM »
The cost of the rebuild kit is one thing to take into consideration, but don't forget the bill at the machine shop.  Don't know what is available around you, but you're looking at a couple hundred $$ for bore/hone, and the costs go up from there depending on what is needed (things like valve job, head machining, block decking, crankshaft grinding, etc.)
My vote would be to do the 1.6L swap.  The 8 valve is a super easy swap and there's no substitute for those extra few cc's.
My rig is a fusion of Jazz and Funk; I call it JUNK
Offline GO_OUTSIDE!
  • 182
  • Sammy Jack
« Reply #8 on: August 31, 2012, 08:11:03 AM »
I bought an 8V from Sean at aftermarket 4x4, I am in the process of replacing the seals, belts and water pump. I am hoping to have it in and running this weekend.
Any one know where to get an FSM by tommorow so I can get the timing right, since I screwed up and lost track of it? Suzukiinfo doesnt have one listed for the 1.6L 8V.
If this is easy i am very glad I didnt choose hard.
« Reply #9 on: September 02, 2012, 07:42:54 AM »
I have a Vitara FSM here:
http://www.rhinoman.org/manuals/vitara/SE416_FSM.pdf
its pretty much all the same as the Track/Kick.
Offline GO_OUTSIDE!
  • 182
  • Sammy Jack
« Reply #10 on: September 03, 2012, 07:38:03 AM »
thanks for the FSM link!
