Technical Discussion - Beginner / Repair
Water in oil question?
c3006
263
10
August 16, 2012, 02:11:20 PM »
I have a Sami with stock 1.3 that was running but got a lot of water in oil. I pulled the head and had it decked and pressure checked put on a new head gasket. Did not see anything wrong visually . Started it back up and had water in oil again after 5 min. Anyone recommend something that might be causing it. Thanks. Clint
inchaos10
162
Re: Water in oil question?
August 16, 2012, 05:21:47 PM »
Could be a cracked water jacket in the block its self crossing over into the oil..? or possably the block needs to be decked..
fordem
4334
170
August 16, 2012, 06:32:55 PM »
The intake manifold has coolant flowing through it, a leaking gasket, where it meets the head or the carb, can result in coolant in the oil.
c3006
263
10
Reply #3 on:
August 17, 2012, 03:09:59 AM »
I'm going to try and find something to pressurize the coolant system this morning and see if I can tell anything about it. I hope it's the intake manifold gasket Fordem. Thanks for the help. c
zorproducts
54
I Love ZUKIWORLD!
Reply #4 on:
August 17, 2012, 07:45:48 AM »
The best way to pressurize an engine is to use a compression gauge, remove the gauge and use compressed air through the spark plug hole. With the radiator cap off If you see bubbles you have a bad head gasket or cracked block. If coolant rushes out of the radiator you got a big problem. Looks like a tear down to me.
MY
c3006
263
10
Reply #5 on:
August 17, 2012, 10:33:46 AM »
I went to my local advance auto and checked out there coolant pressure check tool and pumped 25 lbs of pressure in the system. I noticed water dripping out of the intake gasket below the intake so I brought up the #1 piston and let it set and water gathered on top of the piston,I could see it thru the spark plug hole meanwhile the pressure had dropped to about 5 lbs. pulled the intake off and it was pitted pretty bad around #1 and #3. Took it to the machine shop to get it machined off a little. When I get it back together I will check each cylinder with pressure to see where I am at. Thanks for the help. c
c3006
263
10
Reply #6 on:
August 24, 2012, 03:41:44 PM »
Intake manifold was cracked. Put on another one and all is fine. Thanks. c
