Gearing & Diffs, after bigger tyres
  • 2708 Views
Offline chrisvitarasport94
  • 228
« on: April 07, 2004, 03:39:06 AM »
I'm missing my 5th gear now that I have 30.5"/235's on my '98 8V 1600.   :(
I had to use 4WD-L for the first time tis weekend, and whilst I understand gearing etc I don't know much about the options available for swapping diffs ect. What ratios are popular and where from?
see my exploits at; www.hometown.aol.co.uk/isaacsirnewton/middevonmudflickers.html
Re: Gearing & Diffs, after bigger tyres
« Reply #1 on: April 07, 2004, 05:29:00 AM »
To help out on road you would need to reduce the axle gearing. Calmini http://www.puresuzuki.com sell sets of 5.83:1 gears. I believe that you currently have 5.12:1 so it would be a big help. I'm running the 5.83's with 33" tires and use 5th gear in the interstate at speeds of 65-75 mph.
Off road benefits would come from the axle gearing but you can gain alot more by doing a 4:1 T-case reduction. The only bad part about that is that it will not reduce you high range, so it will not help on the road.
Offline DaddyDave
  • 204
  • Indeed
« Reply #2 on: April 07, 2004, 11:47:10 AM »
wait for bobzooki to come back from moab to tell you just how much he likes the calmini t-case gears.  He was raving on them here and on pirate
Offline idaholwb
  • 772
« Reply #3 on: April 07, 2004, 05:06:18 PM »
 Personnally, I think you should cheat and go through www.ottindustries.com and use their kicker3 that mates the kick/vitara transfer case with the sammy transfer case, you get many benefits and gear selections and gearing correction in high range of 14%....the sammy case has a 1.4:1 reduction in high, the kick is 1:1 in high. Your overall low range ends up being about 4.104:1 in compound low, and is cheaper than doing the Calmini 4.24:1 gears.
Just a thought. ;D
97 Sport
265/70-16s
2" lift
2.0 swap
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #4 on: April 08, 2004, 12:04:30 AM »
14% or 40% change to high ratio?  ;)I looked at this option but I don't want to run larger than 32's and figured it was too much even though it is cheaper so I'm going 5.83's and crawlers.
Offline idaholwb
  • 772
« Reply #5 on: April 08, 2004, 06:53:20 AM »
 Look at it this way. A sammy with that case and 5.12s can run as small as 31s with no ill effects. I think the extra reduction will help in the long run.
97 Sport
265/70-16s
2" lift
2.0 swap
Offline mtntoy
  • 45
« Reply #6 on: April 08, 2004, 07:32:49 AM »
4.16 transfer gears will reduce your hi ratio gearing by about 12%.  Guess what the difference between stock tires and 235s are?  12%!!  You will return to stock ratio on the road, and have lower gears off road.  That is a big reason why transfer gears are so popular, they reduce low ratio gears more than hi ratio gears.  R|removethispart|@P gears reduce both by the same ratio.
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
« Reply #7 on: April 08, 2004, 12:54:00 PM »
Just a thought. ;D
WHAT WAS THE COST OF THIS SET UP  ???  AND THEY ALSO PUT IN THE CALMINI ROCK CRAWLER T - CASE GEARS ...IS THIS A NECESSARY EXPENSE  ???  SPEAK SLOWLY I'M MECHANICLY CHALLENGED  ;D MATTY D.  8)
« Reply #8 on: April 09, 2004, 10:27:21 AM »
I think 5:83s on 30" tyres should be just about perfect. Personally I think the Vit/Track/Kick is overgeared in stock form. Having driven mine once with 25.5" tyres on it I know that it really flies along on lowered gearing (of course the speedo reads a little high too). That is of course a UK opinion, I think in the US you are used to big low revving engines and would probably find it a bit buzzy, no offence meant. I should also point out that mine is an 8V so the 20% extra power of the 16V probably means that the higher gearing suits it more.
« Last Edit: April 09, 2004, 10:28:39 AM by Rhinoman »
