gutless 1.6l 16v
  • 9 Replies
  • 3411 Views
Offline chadstichter
  • 162
  • 98 4door home built coil yota swap 31s rear e-lock
gutless 1.6l 16v
« on: September 02, 2012, 11:38:07 PM »
it has a fresh rebuilt 1.6 16v with only 250 miles on it and it is extreamly gutless. i thought it they were just like that but then i drove a buddys and it is lifted even more with 31s also and it darn near lights them up. i was wondering if any one knows anything that i could to help it. i already have a k&n and i took the plumbing out that goes from the air box to the fender stuff. if anyone knows any other upgrades besides a turbo it would help
thanks
98 4door home built coil yota swap 31s rear e-locker, 8000lb winch and synthetic rope
|...BEER TRUCK..........| ||'|";, ___.
|_..._..._______===|=||_|__|..., ]
 l(|removethispart|@) (|removethispart|@)          l(|removethispart|@) (|removethispart|@)         l(|removethispart|@)
Offline talonxracer
  • 1284
Re: gutless 1.6l 16v
« Reply #1 on: September 03, 2012, 04:41:51 AM »
A 2" exhaust is needed.
Also, even though the engine is freshly rebuilt, do a compression check.
Stock cam?
  • 162
« Reply #2 on: September 03, 2012, 05:30:43 PM »
yeah it has a stock cam i couldnt find anyone to machine mine or a aftermarket one to put in it has a calmini header and a exhaust is comming soon. will no cat help i live in a place where smog doesnt matter
Offline talonxracer
  • 1284
« Reply #3 on: September 04, 2012, 07:30:20 AM »
I only know of two places that advertise high lift cams for the 16v SOHC engines, Suzukird and Zukination, the Suzukird is a complete valvetrain so it is big $$$, the Zukination/Altered Ego cam is a regrind that has the maximum amount of lift as possible without moddified rockers.
« Reply #4 on: September 04, 2012, 10:03:22 AM »
Play with your timing a bit.  On mine when I switched motors I had to switch to running it 2 degrees advanced over stock before it would run well.  Strange as the old motor ran with timing dead on.
  • 162
« Reply #5 on: September 04, 2012, 05:04:18 PM »
okay thanks
  • 162
« Reply #6 on: September 04, 2012, 06:39:49 PM »
so i did a compresion test today cylinder 1: 155lbs 2: 155lbs 3: 155lbs 4: 130lbs  anyone know why
Offline talonxracer
  • 1284
« Reply #7 on: September 05, 2012, 06:19:50 AM »
Add a little oil into the sparkplug holes and retry the compression test(this is called a wet test), also it sure wouldnt hurt to do a leakdown check. #4 does seem to be low in compression, could be rings, valve seat or even too much clearance on the valve lash.
  • 162
« Reply #8 on: September 05, 2012, 07:16:18 AM »
whats a leak down check i havnt heared of that? i will put a little oil on there tonight and try it again
« Reply #9 on: September 05, 2012, 02:43:38 PM »
I would guess that the vakve timing is out. For a cam try SuperF1y on teamswift.net, he has a number of different grinds.
