rear axle bearings sami
  • 2810 Views
« on: September 03, 2012, 10:44:29 AM »
So on my 86 sami with a rear auto locker from what i have found out through here is one or the bearings in the rear axle has broke. So I was wondering how to replace the bearings and if it is a back yard mechanic job or one best left to a pro.
Offline doughboy0379
  • 290
  • 9
Re: rear axle bearings sami
« Reply #1 on: September 03, 2012, 11:59:07 AM »
You could do it yourself, but you will have to pull the axle shafts out of the axle tube. To get them out you will probably need a slide hammer you will also need to replace the axle seals. It can be a lot of work though, you also will need to remove the brake backing plates to get the shafts out.
« Reply #2 on: September 03, 2012, 03:34:20 PM »
well that seems a bit to involved for my skill level and budget. I just dropped a grand on my apartment so I guess ill have to park it till I can afford to have a mechanic do it. But thanks for the help.
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #3 on: September 03, 2012, 05:11:00 PM »
here are a couple of links that might help you with rear axle removal:
Tracker video but the idea is similar:http://www.acksfaq.com/rear_axle_bearing_replacement.htm
Samurai: http://www.zuknation.net/Zuknation/modules.php?name=Forums&file=viewtopic&t=616
...and this one which has some detail on the two types of rear axle bearings that are available:
http://www.zukikrawlers.com/showthread.php?t=2905&highlight=rear+wheel+bearings
I hope that this helps!
Ack
« Reply #4 on: September 03, 2012, 09:21:55 PM »
Looks like I may be able to do that after all. Thanks a ton! Once I get the money ill give it a shot.
