Sidekick drop pitman arm
  • 18 Replies
  • 10257 Views
Offline Mac
  • 407
  • Toys, Toys, Toys
    • 1985 Suzuki Samurai
« on: April 05, 2004, 04:12:35 PM »
Want to open this can of worms up, Calmini now has a Drop Pitman arm for the side kick box, would it help or hinder the steering setup on the three inch lift for the Sidekick.
Mac
Re: Sidekick drop pitman arm
« Reply #1 on: April 05, 2004, 04:29:15 PM »
How much drop is it? and what are they asking for it? core charge?
Offline Mac
  • 407
  • Toys, Toys, Toys
« Reply #2 on: April 05, 2004, 04:32:45 PM »
http://www.puresuzuki.com/kick_pitman_arm.htm
I would expect it is a three inch drop like the other sami one.
« Last Edit: April 05, 2004, 04:36:24 PM by Mac »
« Reply #3 on: April 05, 2004, 04:34:18 PM »
I like it I need one  ;D
« Last Edit: April 05, 2004, 04:54:15 PM by mrfuelish »
Offline Mac
  • 407
  • Toys, Toys, Toys
« Reply #4 on: April 05, 2004, 04:37:28 PM »
It would not grab the image off the site, so a hyperlink instead.
« Reply #5 on: April 05, 2004, 11:10:26 PM »
I dont know if the steering is the same on a Sami as a Kick, but that is to connect a Sidekick Pump to a Sami steering (for 1.6 conversions)
Quote from Calmini's web page:
"Finally a solution for running power steering with the stock steering setup.  CALMINI is proud to introduce the only drop pitman arm specially splined for the Sidekick and Tracker steering box while retaining the stock tie-rod connection for the factory steering setup.  Our 1 piece forged arm is stout and ready for the trail!  Arm is for the Samurai with a Sidekick power steering conversion and the factory steering system."
« Last Edit: April 05, 2004, 11:10:50 PM by Zukipilot »
« Reply #6 on: April 06, 2004, 01:51:39 AM »
It's the same when you put in a steering box out of a kick in it.  ;D even with the ott steering mine still has a little bump steer, I prob. have like a six inch lift on the syspension in front  8)
Offline zooky
  • 135
« Reply #7 on: April 06, 2004, 09:15:22 AM »
this is Calmini's RAISED pitman arm, its for the low riders ;D
« Last Edit: April 06, 2004, 09:16:51 AM by zooky »
Offline Mac
  • 407
  • Toys, Toys, Toys
« Reply #8 on: April 06, 2004, 10:21:10 AM »
I am not talking about putting it into a sami, but into a kick with a three inch calmini lift, would it solve some of the problems with the weak point on the front end, or would dropping it cause other steering issues?
Mac
Offline DaddyDave
  • 204
  • Indeed
« Reply #9 on: April 06, 2004, 10:31:29 AM »
it wont work on a sidekick with the 3" lift.  i think it would actually cause binding as opposed to helping the situation.
Offline Mac
  • 407
  • Toys, Toys, Toys
« Reply #10 on: April 06, 2004, 11:34:39 AM »
Why do you think it would bind DaddyDave, I was concerned that the angle on the steering system are fairly close to the same angle now, but the Drop pitman may cause a bind because of that or it may eleviate some of the stress on the idler arm.
Mac
Offline Yankee Tim
  • 431
  • Who says a GV is a grocery getter?
    • Yankee Off-Road
« Reply #11 on: April 07, 2004, 10:57:11 AM »
It's for Sammy's with Kick P/S and lifts.  Would be find for anything where a normal 3" drop pit would correct.
Also, on big lifts, even with a full high steer, there is still an angle in the drag link.  This, in combo with the hy-steer, would be the ultimate solution.
Yankee Tim
Offline DaddyDave
  • 204
  • Indeed
« Reply #12 on: April 07, 2004, 11:37:53 AM »
IIRC the samurai and sidekick steering are differnet it terms of overall setup.  Something to do with the 'kick being centerlink driven as opposed to box driven from the samurai.  I'll double check and let you know.
« Last Edit: April 07, 2004, 11:38:23 AM by DaddyDave »
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #13 on: April 07, 2004, 11:52:04 AM »
The arm is only for a solid axil front end!!!
With our IFS the lower control arms and the stearing linkage (tierods) must be at the same angle for the best on road stearing.
Mike H.  tried putting the tie rod on top of the control arms instead of the bottom.  That put the tie rodes around a stock placement.  But he found out that on the street it had really bad bump steer and put it back to the way it was.
If you put it on our rigs it would really mess up our stearing.  Because on the other end of the of the center link there's the ideler arm and a drop pitman would mess up that geometry.
32 MTR's Warn 8000i
Offline idaholwb
  • 772
« Reply #14 on: April 07, 2004, 04:56:57 PM »
 COOL!! That would take care of the last little bit of steering woes that we have on Heather's truck! Hehe, can't wait till they get back to tell them! ;D
97 Sport
265/70-16s
2" lift
2.0 swap
