HD Calmini rear axles complete
  • 13 Replies
  • 4032 Views
Offline Bfunk
  • 406
« on: September 10, 2012, 10:05:43 PM »
I am selling my rear sidekick axles.  here's the CL ad  http://seattle.craigslist.org/est/pts/3254674674.html
I would really prefer to sell them in the seattle area. Thanks
Brian
Re: HD Calmini rear axles complete
« Reply #1 on: September 12, 2012, 03:19:07 PM »
Shame they won't fit my 95. On the " other " coast anyway.
Offline Bfunk
  • 406
« Reply #2 on: September 12, 2012, 10:47:12 PM »
They are made to fit that year and older. I think they changed in 96... could be wrong. I luckily have a 93 2wd that I use for parts. I had to run the brakes off of that one.
Brian
« Reply #3 on: September 13, 2012, 04:31:10 PM »
Yeah, I think the spline count may have changed ( more ). Since you have a 93 any way you could compare ?
Offline Bfunk
  • 406
« Reply #4 on: September 13, 2012, 09:28:37 PM »
No, it's just the way suzuki mounted the wheels.  On the early models they were a 4 bolt and on mine they were a 5.  The bolts that hold the drums on.
Brian
« Reply #5 on: September 15, 2012, 04:15:07 AM »
Well that's a bitch. Good luck with the sale.
Offline Bfunk
  • 406
« Reply #6 on: September 15, 2012, 09:34:49 PM »
I could check on shipping, if your interested. Let me know
Brian
« Reply #7 on: September 16, 2012, 06:55:57 AM »
I'd have to dump all my disc brake conversion stuff, not worth it but thanks anyway.
« Reply #8 on: September 16, 2012, 08:08:30 AM »
If I am correct in what you guys are talking about the axles should be interchangeable. The Cherry bomb is a 96 and had the newer style axles. After I broke one in a race I found out they are weaker because of a necked down area. I got a older set of axles and they bolted right in.
Offline willzila
  • 40
« Reply #9 on: September 17, 2012, 10:29:26 AM »
Shot a email your way
Offline Bfunk
  • 406
« Reply #10 on: October 02, 2012, 09:12:19 AM »
Ttt
Offline echojeff
  • 414
  • Lo que sea
« Reply #11 on: November 17, 2012, 06:44:50 PM »
I am just seeing this, and the CL ad is expired.  I have a 95 4 door manual with the noisy rear pinion. Is this something I would need?
95 Kick 4dr JLX.
Offline nprecon
  • 2318
  • 52
  • ONWARD... through the fog!
« Reply #12 on: November 19, 2012, 05:25:18 AM »
Doubtful if your problem is a pinion gear/bearing.  Your pinion rides in bearings inside the nose of your rear differential where it meshes with your ring gear and turns your axles.  There are also shims in your pinion and ring gear that, along with proper torquing and proper back lash measurements, allows your ring and pinion to mesh correctly into the ring gear teeth.  The pinion shaft is inside a sleeve with a flange on the end held in place with a large nut.  The flange bolts to your drive shaft.
« Reply #13 on: November 20, 2012, 07:25:57 AM »
Probably not, unless your noise is a wheel bearing going out.  Even then most would replace the bearing, unless your driving style is breaking axles.  These are stronger axles.
