1st spoa think i messed up help >.<
  • 21 Replies
  • 5805 Views
Offline xxking9
Re: 1st spoa think i messed up help >.<
« Reply #15 on: September 13, 2012, 03:52:15 PM »
Re: skyhiranger i think ill destroy my axle tube grinding old perches off we also welded inside.. i upload pics
« Reply #16 on: September 14, 2012, 06:40:34 AM »
Cut high on the side of the perches, then just keep grinding until you get them ground down flush with the axle tube.
Yeah, it is gonna be a lot of work and you'll have to buy new perches, but IMO that is going to be your best option.
Offline tuxblacray
  • 20
    • Tuxblacray Photos
« Reply #17 on: September 15, 2012, 05:07:53 AM »
Your new Z-Link has left Indiana and is now in Columbus, Ohio..... ;)
Offline tuxblacray
  • 20
    • Tuxblacray Photos
« Reply #18 on: September 15, 2012, 05:31:54 AM »
Your front axle degree is absolutely off as indicated. I would suggest taking a die grinder and removing those perches CAREFULLY.
I have a set of 2" wide perches that might set over the older perch locations and allow you to weld in a newer location. These would be better for you and allow more area for your spring to rest on.
I also have an OEM set of shackles if you need them.
Is that a Michael Knight SPOA lift? It looks like the shackles he makes and sells in his SPOA Lifts. I know those kits are lacking detailed instructions which make it tuff on a new guy.
I will get you the OEM drive-shaft angles this weekend and then you can buy a cheap degree finder from Lowes and set them easily and correctly.
Hang in there your gonna be fine.... By the way that is a nice looking lil Sammy!
        Tux...  8)
Offline xxking9
« Reply #19 on: September 16, 2012, 04:40:27 AM »
Sounds good.  How big r the stock shackles
« Reply #20 on: September 16, 2012, 07:36:12 AM »
2.75" hole to hole, I think.  Yeah, they are pretty short.  Shackles with a 4" or 5" hole to hole measurement are acceptable, IMO.
Offline tuxblacray
  • 20
    • Tuxblacray Photos
« Reply #21 on: September 16, 2012, 02:43:25 PM »
I think Sky is rite... I can't find the stock shackles in any of the Zuk suspension parts tubs. I did find a set of 4.25 (hole to hole) set though...
Your front drive-shaft angle should be set at 8 degree with the rear being set at 10 degree..   ;)
« Last Edit: September 17, 2012, 12:15:52 PM by tuxblacray »
