Clutch replacement
  • 2534 Views
Offline shelton
  • 19
Clutch replacement
« on: September 13, 2012, 06:16:34 PM »
Just replaced the clutch in my '95 Zuki and now I can't get it to go into 1st, 3rd or 5th.  Any help is appreciated.
Re: Clutch replacement
« Reply #1 on: September 14, 2012, 06:37:44 AM »
There is a bushing in the shift tower that the ball end of the shifter fits down into.  A lot of times this bushing gets out of place, when the shifter is removed.  The bushing gets pulled up out of the hole it fits into in the end of the shift rail and the bushing falls into the shift rail area of the transmission.  If when you put the shifter into any gear, and there is excessive side to side play in the shifter (like 6" or so), then the bushing is out of place.  Sometimes the bushing can be fished out with a wire with a hook bent into the end of it (the trick is figuring out where the bushing is in the shift tower area...since you really can't see down into the shift tower very good....other times you have to remove the shift tower from the tranny and disassemble it, to retrieve the bushing.
Offline talonxracer
  • 1284
« Reply #2 on: September 14, 2012, 12:46:55 PM »
I have also seen that plastic bushing forced over the shifter ball end
« Reply #3 on: September 14, 2012, 03:58:19 PM »
Yep, I've seen that a few times too.  I don't know how it gets over the ball on the end, but I've always just popped it back over the ball (with a lot of force) and reused it and it works fine.
Offline shelton
  • 19
« Reply #4 on: September 16, 2012, 08:06:02 PM »
Thanks guys, it was just like ya'll said.  Fished the part out of the transmission, installed it and am now back to running...with all five gears.  Thanks a bunch!
« Reply #5 on: September 16, 2012, 08:31:40 PM »
Cool.
