87 SAMURAI RING AND PINION CHANGE YES OR NO?
  • 20 Replies
  • 7949 Views
« on: September 16, 2012, 06:00:30 PM »
I HAD PUT IN THE 4.16 TRANSFER CASE HOPEING THAT IT WOULD GIVE ME BETTER PERFORMANCE WITH 32" TIRES. BUT THE TRANSFER CASE SOUNDS LIKE IT WON'T  LET ME GET UP TO SPEED WHEN ROLLING AT 45MPH AND UP. SHOULD I START THINKING ABOUT GET THE  STOCK RING AND PINION CHANGED TO GIVE THE T-CASE A BRAKE( IT SOUNDS LIKE NOISY  LIFTERS WHEN I STEP ON THE GAS TO BRING UP TO HWY SPEED, BUT GETS QUITE WHEN I LET OFF PEDDEL AND BACK OFF A BIT...
Re: 87 SAMURAI RING AND PINION CHANGE YES OR NO?
« Reply #1 on: September 16, 2012, 09:42:41 PM »
I would take the transfer case apart first and fix whats wrong with it!
Offline Jonny Rash
  • 1094
  • 21
« Reply #2 on: September 17, 2012, 06:39:41 AM »
Yes, it sounds like the t-case has some issues.  Could be bad u-joints as well.
« Reply #3 on: September 17, 2012, 12:31:58 PM »
there are no problems with my u-joints alls good, and my transfer case is only 2 years old with very little miles on it. it was rebuilt by rocky road . i guess a transmission shop would know how to repair it?
Offline mverley
  • 652
  • 20
  • SPACE JUNK
« Reply #4 on: September 17, 2012, 02:49:56 PM »
Things to check:
1.  Check the u-joints on the rear driveshaft (upper and lower) and the u-joints on the intermediate shaft (NOT the front driveshaft).  There should be no play in any direction.
2.  Check all 3 transfer case mounts, and make sure they are not torn, or damaged in any way.
3.  Check both transfer case mounting arms to make sure they are not bent, twisted, etc.
4.  Check to make sure both front hubs are unlocked and the transfer case is not locked into 4wd (should be able to rotate the front driveshaft by hand)
5.  Do you still have your old tcase?  If so, swap it in and see if the noise goes away...if it does, then you know that the tcase is the source of the noise.
You need to sort out what is making the noise before you go after the gears in the axles.  Bent/damaged tcase mounting arms and/or rubber mounts are very common after installing low gears in the tcase.  It takes very little misalignment to cause a vibration in the driveshafts.  I have also seen hubs fail to unlock, spinning the front driveshaft and causing a loud vibration/noise.
« Last Edit: September 17, 2012, 04:51:17 PM by sewerzuk »
My rig is a fusion of Jazz and Funk; I call it JUNK
« Reply #5 on: September 19, 2012, 02:29:51 PM »
I CHECKED ALL U-JOINTS, T-CASE  MOUNTS ,MOUNTING ARMS  AND NO ISSUSES THERE . I TOOK OFF FRONT DRIVE SHAFT AND TOOK A SPIN AND NO PROBLEM ON ROAD , I PUT IT IN LOW 2 WHEEL DRIVE ,AND NO PROBLEM. THAN I PUT THE SHAFT BACK ON AND IT STARTED AGAIN WITH NOISE. YOU SAY IN NUTRAL I SHOULD BE ABLE TO TURN DRIVE SHAFT UP FRONT .
IS THAT JACKED UP ? I HAVE LOCK RIGHT LOCKERS UP FRONT AND BACK.
Offline zuki1018
  • 397
« Reply #6 on: September 19, 2012, 02:40:15 PM »
Just curious... did the case swap do you pretty good with the 32's?  ... noticeable difference I mean?
« Reply #7 on: September 19, 2012, 04:28:26 PM »
THE 4.16 TRANFERCASE DID REAL GOOD WHEN I TOOK OFF THE FRONT SHAFT. IT GOT UP TO SPEED WITHOUT ANY PROBLEM. AND YES WITH 32" BAJA CLAWS. I'M NOT THAT SURE ABOUT TAKING THE T-CASE APART AND SHIPPING IT BACK TO ROCKY ROAD IS OUT OF THE QUESTION , WOULD A TRANSMISION PLACE DO?
« Reply #8 on: September 20, 2012, 05:53:22 AM »
Is your caps lock key broke?  If not, turn the damn caps lock off.
You won't be able to turn the front driveshaft when the tcase is in neutral (to access neutral in the tcase, you have to shift into 4x4 first, so the input and output shafts are all locked together, even though the tcase is in neutral).  The only time you should be able to turn the front driveshaft by hand is when the tcase is in 2wd high....and the front hubs have to be unlocked (in the "free" position).  None of this makes any difference if you have lockers or not.
Offline mverley
  • 652
  • 20
  • SPACE JUNK
« Reply #9 on: September 24, 2012, 07:22:56 AM »
 :laugh:
I was saying that you should be able to turn the front driveshaft by hand with the front hubs unlocked, transfer case in 2wd high, and the transmission in neutral.
The fact that the sound disappeared when you removed the front driveshaft suggests that you don't have a problem with the transfer case.  Maybe one of your hubs isn't unlocking.
Offline mverley
  • 652
  • 20
  • SPACE JUNK
« Reply #10 on: September 24, 2012, 09:32:14 PM »
Also, it takes very little for the mounting arms to twist; you might not be able to see it.  Minor misalignment of the intermediate shaft causes a pretty significant vibration.
My best guess is that nothing is wrong with your transfer case...I've seen very few of them with issues.  It is usually a bad u-joint, improper driveshaft geometry, bent transfer case arms, or bad transfer case mounts.
And, your question about whether or not a transmission shop can handle your transfer case is too vague for anybody to answer here.  The samurai transfer case isn't too complicated as far as gearboxes go, but it is kind of unique in that it has both high and low range reduction.  Who knows what you'll get if you take it into a random transmission shop.
« Reply #11 on: October 07, 2012, 03:52:39 PM »
HI ,  I CHECKED ALL T-CASE MOUNTS, ARMS, BUSHINGS , U-JOINTS, DRIVESHAFTS, AND THERE ARE NO ISSUES. I INSTALLED A HEAVY DUTY T-CASE CRADDLE AND NEW RUBBER  MOUNTS  SO THATS ALL GOOD. I PUT TRANS IN 2ND GEAR , T-CASE IN 2 HIGH  AND WAS ABLE TO TURN FRONT DRIVE SHAFT  WITHOUT ANY PROBLEMS. SO DO YOU THINK THAT IT'S  JUST MAY BE THE HUB LOCKS  THAT ARE NO GOOD ? I DO REMEMBER WHEN I REBUILT FRONT AXEL( I PUT NEW POWERTRAC   LOCKERS, AND BEARINGS,AND SEALS.  THAT  ONE HUB LOCKER WAS KINDA DIFFERENT AND THE SPRING DIDN'T FEEL THE SAME BUT INSTALLED ANYWAYS THINKING IT WOULD BE FINE.THEY LOCKUP GOOD BUT MAYBE DON'T UNLOCK COMPLETLY AND THATS THE NOISE I HEAR ?
« Reply #12 on: October 07, 2012, 05:23:01 PM »
how much lift do you have and did you clearance the yokes on your drive lines so they do not bind or hit each other when the diffs drop? it is kinda rare but you can break the end off of your front out put shaft (transfer case front flange) where the needle bearing goes on it.
« Reply #13 on: October 07, 2012, 05:31:20 PM »
I have the 5" LIFT KIT FROM CALMINI  AND IT FEELS FINE .
« Reply #14 on: October 07, 2012, 05:42:19 PM »
what I was asking was did you take the u joints out and grind some mettle off of the yokes for clearance?
