Ill driveline effects from lowering the case?
  • 1844 Views
Offline zuki1018
  • 397
« on: September 19, 2012, 08:16:46 AM »
...wondering if a lowered sami case (2") would effect short drive to tranny? Assume the 3 stock mount locations were lowered to keep same angle.
Offline Jonny Rash
  • 1094
  • 21
Re: Ill driveline effects from lowering the case?
« Reply #1 on: September 19, 2012, 11:07:04 AM »
Why do you need to lower it?
Offline zuki1018
  • 397
« Reply #2 on: September 19, 2012, 12:04:43 PM »
Lower droop and not spending $$ on CV's or custom shafts mainly.
« Reply #3 on: September 19, 2012, 01:47:27 PM »
If you keep the planes equal so the u-joints are lined up properly you should be able to get away with it.  How high are you going?  You might be able to get away with stock t-cases if you slide the rear axle back.
Offline zuki1018
  • 397
« Reply #4 on: September 19, 2012, 02:35:19 PM »
Great.  I actually lowered the case appx 2.5" while keeping the same angles. I also built a frame to protect the case should I pyramid.  Further down the road I plan to run 35's so I feel the sacrifice of a lower belly is worth the trade-off.  Im mainly after water clearance and flex.
My trouble started with 4x YJ's and 4x missing links. Full droop was not quite enough for the u-joints. I lengthened both drive shafts and removed the existing spacers I was running (pre YJ). Thx for the responses.
