Rebuild case & now making noise (video)
  • 0 Replies
  • 1362 Views
Offline zuki1018
  • 397
« on: September 19, 2012, 02:56:09 PM »
Hey folks thanks for looking.
The sound to listen for is the clicking/grinding.. (as if i am moving a microphone around.. i kept the video completely still)
I recently rebuilt this sami case myself and installed the TT shifter kit.  The best way I can describe the sound is 2 gears not fully locking... or what you could imagine a partially worn gear engaging to sound like.  It seems to be more predominant when i am coming to a stop and pressing the clutch in. Doesn't matter if I am in 2/4 or H/L.  The other (related?) issue I've had is the case popping out of gear while under full load (7psi of boost).  It only does it in 2/4wd high. Low gear stays in gear always.  It is not the shifter moving out either as I have strapped it to be sure. Brent |removethispart|@ TT mentioned a slightly bent shifter fork which makes sense to me.  Thought it was worth a mention as it could lead your opinion of the noise in another direction.
TIA
