Tare down for front axle.?
  • 2306 Views
« on: September 19, 2012, 10:17:15 PM »
Well on my 86 Sami lifted with 30s I was having a h
Popping noise from the rear. I tore it down and the diff was diff was full of mud water so that's not a very good lubrication...whoda thunk it. So I drained the front diff same thing. But I do not know how to Tare down the front. Any advice?
Offline ecoast
  • 509
  • 8
    • East Coast Canvas
Re: Tare down for front axle.?
« Reply #1 on: September 20, 2012, 05:56:54 AM »
there is a good write up on izook.com
Offline crewcabrob
  • 348
« Reply #2 on: September 20, 2012, 07:26:42 AM »
Would you say it was a pop or a muted clunk?  I thought I had a bad u-joint, but when I turned the drive shaft to see where the play was, it really sounded like it was inside the pumpkin.  I'm worried my gears are shot and I will need to tear down the rear axle.  My biggest fear is I will then need to put an ARB in there while it is torn apart.
Rob
« Reply #3 on: September 20, 2012, 08:05:15 AM »
Rob
for me it was fairly obvious once i got underneath the sami. It was a very loud pop and felt like the gears werent releasing. I took the drive shaft off and i was able to wiggle the output shaft. I have it apart now and it is one of the many bearings that went out. its a fairly easy and cheap fix. im gonna repair both front and rear while im at it.
Offline crewcabrob
  • 348
« Reply #4 on: September 20, 2012, 08:24:04 AM »
Thanks!  I will be taking the drive shaft off this week to clean it up and give it a fresh coat of paint when I put the new 6.5:1 t-case in.  I'll see how much play there is at the output shaft and acess from there.
Rob
« Reply #5 on: September 21, 2012, 01:12:43 PM »
Good luck! Have fun with that t case.i want one with those gears I'd be set if I had that!
