Towing Question
  • 1992 Views
Offline myvega
Towing Question
« on: September 22, 2012, 08:01:43 PM »
I have an 86 Sami that I tow behind a 36 foot Motorhome, the sami has a front tow bar. When I go around a sharp corner the front wheels on the sami want to turn the wrong way. I've tried two different tow bar and still have the same result. HELP
Offline DonD
  • 140
Re: Towing Question
« Reply #1 on: September 23, 2012, 10:15:44 AM »
Have towed Vdubs and used a bungee from steering wheel to seat frame to dampen. Worked.
Central AZ
'90 Tracker
8k Smitty Winch
Man. hubs
Skids
Nerfs and sliders
Lockrite rear
OME susp
4.24 TC
ZOR Ft Bumper
Offline myvega
Re: Towing Question
« Reply #2 on: September 23, 2012, 04:27:33 PM »
Funny you say that, after it happened twice to me yesterday I ran a bungee that way and it never did it again. I was reading on a different forum about checking the caster, if its to far back it will do that. So a alignment shop is in my future. And thats for replying.
Offline tombstone
  • 212
Re: Towing Question
« Reply #3 on: September 24, 2012, 05:25:53 PM »
Seems to me like a towed vehicle would HAVE to turn the same direction as the towing vehicle... ???
Offline Pest!
  • 52
  • on the road again
Re: Towing Question
« Reply #4 on: September 29, 2012, 12:23:14 PM »
I have towed mine thousands of miles. Noticed I needed to release the emergency brake and as well as turn igntion to unlock the stearing. I also remove the front drive shaft because the neutral position on the Tcase still leaves the front shaft engaged with the rear shaft. If you have done all that then I would check your front bearings and knuckles for excessive play or if you have a lift it could be the axel is tilted to keep drive shaft angles and at same time ruin caster settings... Caster and camber doesn't change by itself.
88.5 Samurai,1.6L 16V Tracker obdII, Calmini reversal with 5" lift., Bushwackers, Rockrawler wheels w 33" 1050/15 BFG KM2s  ,TC. Bumpers, Lockers,  4.16 Tcase, power steering , oversize fuel tank, Warrior Rack
Bob
