RTI Ramp
  • 2499 Views
Offline TN_Tracker
  • 1113
    • TN Tracker's Suzuki Space
RTI Ramp
« on: April 04, 2004, 07:22:22 AM »
Here's a pic taken yesterday before the coil spacer lift:
It's a 30 deg. ramp and I scored a 413. Haven't had a chance to test it since the lift.
Re: RTI Ramp
« Reply #1 on: April 04, 2004, 10:30:10 AM »
If you make a run at it, you'll get alot farther.  hee hee
Offline TN_Tracker
  • 1113
Re: RTI Ramp
« Reply #2 on: April 04, 2004, 10:43:04 AM »
Yep, a friend of mine from our club almost put his Bronco on its lid right before I tried the ramp. :o
Offline Kreg
  • 795
    • Island 4x4
Re: RTI Ramp
« Reply #3 on: April 04, 2004, 11:32:30 AM »
A rear locker will help you a lot on an RTI ramp. It gives you that extra little push where a regular diff would start spinning out.
Also try doing it on pavement.  If your on gravel or dirt your tires will start spinning before your truck maxes out.
Offline 1bigtracker
  • 3409
Re: RTI Ramp
« Reply #4 on: April 04, 2004, 12:32:47 PM »
it could if his tires are rubbing on the body.
stu
Offline TN_Tracker
  • 1113
Re: RTI Ramp
« Reply #5 on: April 04, 2004, 12:42:53 PM »
will his rti be higher with coil spacers?? i dont know anything about track kicks
Once I do the strut mount flip and get longer shocks for the rear it will. ;D As Kreg stated a locker would have also helped. I had a ton of wheelspin on gravel.
Offline Kreg
  • 795
    • Island 4x4
Re: RTI Ramp
« Reply #6 on: April 04, 2004, 12:44:09 PM »
I don't think the truck will flex any further even with the coil spacers installed.
Shock length is the main factor when it comes to flex because it is usually your shock that limits the travel of the axel.
Coil spacers (or longer coils) just make the truck sit higher on the shock's stroke, which in conclusion lifts the truck higher.
If you want your truck to flex more you will need to install longer shocks to utilize your longer coils.
Edit: Doh! TN_Tracker beat me to it :P
« Last Edit: April 04, 2004, 12:45:17 PM by Kreg »
