Need advice: Taking out Homemade lift!
  • 2231 Views
« on: October 05, 2012, 09:04:59 PM »
Hey guys,
So I bought a samurai a few months ago with a homemade SPOA made with blocks and just altogether not good. It's on 35's with supposidly 5:29 r&p (probably 5:12 or 5:38) and a rear locker. All on stock axles ( also not that great). Fortunately the body and frame is mint so I have a good base to start.
I've come across a great donor samurai with brand new 31x 11.5 x 15 bfg km2's as well as a lot of great parts.
For now I'm going to remove the blocks on the lift to bring it down to a standard SPOA size and run the 31's and someone is buying the 35's. Here are my questions:
1. I need to know how my rig well run with this gearing and 31's. I won't be doing much highway going. Mostly a hunting rig.
2. Should I be touching the t/c ratio from stock with this setup?
3. My plan for next spring is put the TrailTough complete yj kit for $1359. Does this cover all my suspension needs(high steer, proper SPOA).
4. Well I need to go to a 32-33 tire to fill the wheel wells, I hate too small of a tire with lifts.
Thanks guys. I have done my research and read 100's of pages. Any other advice is appreciated.
Offline Perryd
  • 202
Re: Need advice: Taking out Homemade lift!
« Reply #1 on: October 06, 2012, 08:35:32 AM »
not really related, but i saw that samurai with 31s for sale the other day, would of scooped that up for sure if i had the space. basically a free sammi with the purchase of tires and rims lol
1998 Tracker 2 door soft top, 3spd auto, 4x4, 215/57R15 BFG A/T, bone stock.
Offline jcowdin
  • 111
« Reply #2 on: October 06, 2012, 10:43:11 AM »
When I bought my first Samurai, even with stock gearing, tires and no lift, I always thought it was geared to high.  I completed a SPOA lift and installed 31x10.50x15, I also installed this gear set from:  http://www.trail-gear.com/samurai-transfer-case-gears
It helped a lot and was very easy to install.  I didn't purchase the optional output flanges and don't think I'll ever need them.  I had the chance of driving a friends Samurai that he installed lower R&P's and still had stock tcase gears, with almost the same lift and tires and he really lacked low range.  I felt some difference from the R&P swap but I suggest change the tcase gears and that is all!  Thanks, hope this helps!
The Price is Right!
Offline tj454zuk
« Reply #3 on: October 07, 2012, 03:41:12 PM »
looking at doing one of those transfer case gear sets but im not sure 600 bucks is in my old ladys budget ;)
is there a cheaper place out there?  and are they difficult to install  very limited on tools right now
Offline zuki709
  • 190
  • 6
« Reply #4 on: October 14, 2012, 06:23:34 PM »
if you need someone to haul away that bikini style hard top i can do that for you. ;)
91 Samurai in many pieces
01 Tracker MUD CHILD's 2" suspension lift & 2" body lift. air lift air bag 1000 in front. 31x10.50X15 on stock samurai wheels.
