1985 sj410 carb
  • 2739 Views
1985 sj410 carb
« on: October 09, 2012, 08:00:16 AM »
so i traded me up a 85 sj410 in great condition except the carb,real nightmare.looking for something to replace it with.also have a 87 sammi with 1.3 was thinking i would take it and tranny and swap into the sj410,anyone ever done this swap.
Offline Jonny Rash
  • 1094
  • 21
Re: 1985 sj410 carb
« Reply #1 on: October 09, 2012, 08:52:04 AM »
I think that is a fairly common swap, but you will need to make new mounts for the engine and tranny on the SJ410 frame.  You might also need a small body lift or a Samurai hood to clear the engine.
I've read that the SJ410 carbs were actually pretty good, better than the Aisin or Hitachi carbs on the 1300 engine.   Although, I have no personal experience with them.   I seem to recall that the SJ410 carb was a sidedraft carb.  Take a picture of what you have and post it please.
Re: 1985 sj410 carb
« Reply #2 on: October 09, 2012, 09:33:01 AM »
it side a side draft,somebody already tried to fix it.just cobbled it.looking for a replacement.
Re: 1985 sj410 carb
« Reply #3 on: October 09, 2012, 03:14:37 PM »
The SJ-410 has a side-draft carb stock.  It might be a bit plugged up though, I had one that needed to be rebuilt but I just bought one off ebay instead.  If you go with an earlier SJ-410 carb it gets rid of a lot of the vacuum lines.
I never had a problem with the stock 1.0L other then it not having a lot of power.  It ran like a top even though I ignored it for the most part and would run at just about any angle.
