where to start
  • 1986 Views
Offline Mike71
  • 1449
where to start
« on: April 03, 2004, 07:14:18 AM »
ok i have a 91 tracker 4wd 5 spd 2 door soft top
bone stock..totaly  :o
so i was wondering if i should start with the BL from calmini or the sus lift??
what i want to do is do one either the BL or the sus lift then buy new tires..but i want the new tires to be usable with both the bl and sus lift..so which lift would allow me to run big enough tires that when i went with the other lift they wouldnt look stupid??
also this will be my first major car project..so should i do the BL to get some practice before the sus..or could i muddle through a sus lift?
thanks for any input if somehting i said didnt make sense lemme know and ill try to clarify
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
Re: where to start
« Reply #1 on: April 03, 2004, 07:41:53 AM »
A FRIEND OF MINE & I PUT THE CALMINI 6" COMBO LIFT ON MY 95 4 DOOR KICK.(ME NEVER DONE ANY LIFTING ,FRIEND DOES BUT NEVER TO A ZUKE )  WE FOUND PUTTING THE BODY LIFT TO BE MORE OF A PAIN IN THE A$$ FOR SOME REASON. THE SUSPENSION WENT WELL JUST TOOK A WHILE , LOTS OF UNWILLING BOLTS TO COME OUT . BUT WITH A SMOKE WRENCH, BFH, AND A SAWZALL WE GOT IT DONE. DEPENDING ON WHERE YOU LIVE RUST MAY NOT BE A PROBLEM.  AS FOR DOING ONE OR THE OTHER, I'D CHOOSE THE SUSP. LIFT 1ST IF MONEY ALLOWS. ARE YOU WILLING TO DO SOME SHEETMETAL WORK  ??? IF SO YOU COULD POSSABLY GET 31'S ON & WOULD LOOK OK WHEN YOU ADD THE BODY LIFT. I HAD 32'S THEY RUBBED , JUST PUT 31'S ON NO RUB AND LOOKS GOOD TO ME . ( NO SHEETMETEL WORK ON MINE ) AS FOR DOING IT YOURSELF DEPENDS ON TOOLS AVAILABLE &  HOW COMFORTABLE YOU ARE AT TAKING APART YOUR WHOLE SUSP. AND PUTTING BACK IN .  THE BODY LIFT IS CHEAPER & PROBABLY EASIER ...EITHER WAY HAVE A BACK UP CAR TO DRIVE FOR A FEW DAYS IF ITS YOUR D.D.  THATS MY 2 CENTS ......GOOD LUCK  ;)  MATTY D.  ;D
Offline Speedracer7c
  • 2210
Re: where to start
« Reply #2 on: April 03, 2004, 09:22:53 AM »
Matty, we need some pics of the new shoes on the kick!!!
Offline Mike71
  • 1449
Re: where to start
« Reply #3 on: April 03, 2004, 09:49:33 AM »
lol yah i have another my CBR i can ride to work if need be
  • 2274
Re: where to start
« Reply #4 on: April 03, 2004, 11:38:51 AM »
YEA I'VE GOTTA BORROW A CAM. TO GET SOME NEW PICS.  ;D
