Rocker panel rock sliders
  • 13 Replies
  • 6621 Views
Offline SDS1992
  • 42
« on: October 14, 2012, 06:49:26 PM »
My rockers have needed replacing for some time now. The inner and outer  rockers both couldnt be saved.Did a lot of researching over the past couple of weeks getting some ideas.  I knew I didn't want to weld in replacement rockers so I seen a post on rockers that were also rock sliders.  But all the ones I found were on 1st gen trackers and used box tubing. So I did some brainstorming and came up with using 5" by 1/8" thick round tubing. So I started with the drivers side today and it came out better than I thought it was gonna! I'll post pics in the next couple of days
2000 chevy tracker 4 door 2.0l 4x4 225xxx miles~ jeffs 2" spacer kit, KYB struts, removed sway bar, XL 7 coil springs in rear with rancho 5158 shocks, 235/75/15 Mastercraft MT tires mounted on 15x8 steel wagon wheels, 1.25" wheel spacers, custom skid plate and 5 inch pipe rocker panels/rock sliders, 2 kc daylighter offroad lights mounted to top of fenders
Offline ZR2Trackerjoe01
  • 40
  • 02 Tracker ZR2,
Re: Rocker panel rock sliders
« Reply #1 on: October 15, 2012, 04:42:36 PM »
Any plans on rhino lining or similar bedliner coating?
02 ZR-2, Jeffs Kit, Doestch shocks, Warm Premiums.
Offline SDS1992
  • 42
« Reply #2 on: October 15, 2012, 05:53:31 PM »
I want to but I don't know what to use. I've tried different bed liners and undercoatings on other things and didn't like any of them. I just painted it black for now. Got any suggestions on products to try?
Offline zuki709
  • 190
  • 6
« Reply #3 on: October 15, 2012, 07:10:59 PM »
i find the rustcheck bedliner good so far i've only been using it for 6 to 8 months so long term use hasn't been proven yet.
91 Samurai in many pieces
01 Tracker MUD CHILD's 2" suspension lift & 2" body lift. air lift air bag 1000 in front. 31x10.50X15 on stock samurai wheels.
Offline SDS1992
  • 42
« Reply #4 on: October 15, 2012, 07:42:14 PM »
where can i get it?
Offline zuki709
  • 190
  • 6
« Reply #5 on: October 16, 2012, 11:01:34 AM »
up here in canada, you can get at wal-mart and canadian tire.
  • 40
  • 02 Tracker ZR2,
« Reply #6 on: October 16, 2012, 05:26:52 PM »
I have thought about just doing my rockers when i repair my rust in a bedliner but dont live in canada- any good usa products?
Offline nprecon
  • 2318
  • 52
  • ONWARD... through the fog!
« Reply #7 on: October 16, 2012, 09:25:03 PM »
I am going to try Monstaliner next time.  They have a wide array of colors and they sell a liner without the rubber particles Herculiner has.  It goes on with a better final texture: no nibbles.  They also make the Chassis Saver product.  You can request four color chips (for free) from their color selection to make sure the color you think you want is the color you will actually get.  I was only interested in one color, but you have to request four.  It turned out well.  The color I thought I wanted had more purple in it than it appeared to have on the web site and the color next to it was closer to what i had in mind.
http://monstaliner.com/
I won't be using the Herculiner product again.  I put three coats of it on my rockers (four years ago) and they didn't hold up to the chipping/rusting at all.  I think Herculiner does not have the UV resistance it needs to have.  When I coated my brush guard with it about 18 months ago, I just dipped the liquid part and tried NOT to get too many rubber particles in the coating.  I put three coats of Herculiner fluid on the brush guard.  After it dried I sprayed three coats of Rustoleum semi-gloss black over it to keep the sun from degrading it.  So far, so good.
Looking forward to seeing your finished sliders.   My rockers will need attention/replacement by next spring (dammit!).  I have some rectangular tubing on hand for it now, but I'm totally open to new/different ideas.
« Last Edit: October 16, 2012, 09:30:31 PM by nprecon »
« Reply #8 on: October 17, 2012, 10:14:35 PM »
I tried Hurculiner on my sliders.  I does not hold up, it is like course sandpaper and holds mud and dirt better than anything.  I would not use it as a last resort.  And it catches fire real easy.
I am looking forward to photo's of your sliders.
Offline SDS1992
  • 42
« Reply #9 on: October 18, 2012, 06:02:00 PM »
heres some pics
all welded in
finished product
Offline Perryd
  • 202
« Reply #10 on: October 19, 2012, 07:46:19 AM »
i love it! makes me want to do the same even though i already bought replacement rockers. What kind of welder did you use? how long did it take you?
1998 Tracker 2 door soft top, 3spd auto, 4x4, 215/57R15 BFG A/T, bone stock.
« Reply #11 on: October 19, 2012, 08:20:54 AM »
It looks good on your tracker. Nice job, and much stronger than the tin panels you replaced.
Offline SDS1992
  • 42
« Reply #12 on: October 19, 2012, 09:23:32 PM »
Thanks! I actually used the 90 amp mig welder from harbor freight.  Best $100 I've ever spent! It really surprised me how good it works for the price! I worked on it pretty much all day Sunday and finished painting it at 8 Sunday night.
Offline max-zr2
  • 45
« Reply #13 on: October 20, 2012, 04:58:31 PM »
Did mine a couple months ago,  used 3- 5' sections of 1 1/4" square tube, and 2- 5' sections of 1". Put some fiberglass over top and some rubberized rocker guard.  I am very happy with the final product,   rockers finally meant for rocks  ;D
Installed:
- Jeff's 2" coil spacers,  Doestech shocks (21.5-13.5),  free wheelin' hubs, 15"X8" American Racing rims (4"backspacing), 30X9.5 General Grabber AT2's, K&N Filter, Snorkel,  XL-7 Rear springs
Installing:
- 2" BL
