XL7 Question
  • 3160 Views
Offline gilty
  • 11
  • Zuki54
XL7 Question
« on: March 26, 2004, 07:30:30 AM »
Can any one tell me where the mysterious passenger compartment hepa filter is located on the XL7 and how to change it?
I am assuming it's an OEM part and will cost me at least half a C note.
Thanks,
Gilty
Offline Bobzooki
  • 1754
  • Web Wheeler
Re: XL7 Question
« Reply #1 on: March 26, 2004, 08:12:24 AM »
I'm guessing an OEM HEPA filter will probably set you back more than one c-note!
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
lucszuk
Re: XL7 Question
« Reply #2 on: March 26, 2004, 08:20:56 AM »
i couldnt find it either!! i look for  like ever on my moms and i wasnt even liek there?
Offline jagular7
  • 1026
  • Jagular7
Re: XL7 Question
« Reply #3 on: March 26, 2004, 08:28:42 AM »
Let see if I can help. IIRC, it's located under and behind the glove box. You'll need to remove this out of the way. In the ductwork there is a channel about 1" is width. This is the filter and it's '?holder?'. To give you a comparison, think of your house filter for the air return. There should be some snap clips you pop, and the holder slips out.
Lenexa, KS
Offline gilty
  • 11
  • Zuki54
Re: XL7 Question
« Reply #4 on: April 01, 2004, 03:07:59 AM »
 :)Thanks Jagular7, I'll check it out this weekend.
gilty
Offline jagular7
  • 1026
  • Jagular7
Re: XL7 Question
« Reply #5 on: April 01, 2004, 07:40:14 AM »
I've found the instructions for swapping the filter out. I'll scan it tonight and post to my webshots album.
Lenexa, KS
Offline jagular7
  • 1026
  • Jagular7
Re: XL7 Question In-cab air filter
« Reply #6 on: April 02, 2004, 12:15:54 AM »
Couldn't locate my USB cable for the scanner. But I was able to locate the instructions on the web.
Go to http://www.pureoil.com. Click on the Air Filter, Cabin Air Filter, Premium Plus link in the upper right portion of the header. Link to the installation instructions. Link to P/N C15506 (left column about 7 down). There you have it.
Acrobat Reader will be necessary. Good luck.
Lenexa, KS
Offline Samurai_Hamster
  • 28
    • Samurai Hamster
Re: XL7 Question
« Reply #7 on: April 02, 2004, 12:39:42 AM »
Its not too hard, but getting the cover off is a bit aggrivating as the g***** dash support brace is in the way.
There is a place in St Louis that sells these filters a bit cheaper than the dealer
Or see if your local auto store has them now.
