Stupid question
  • 12 Replies
  • 3122 Views
Stupid question
« on: October 23, 2012, 12:44:02 PM »
This may be a stupid question, but what are duels?
Offline crewcabrob
  • 348
Re: Stupid question
« Reply #1 on: October 23, 2012, 12:57:00 PM »
Duel carbs or duel exhaust?
Offline tuxblacray
  • 20
    • Tuxblacray Photos
Re: Stupid question
« Reply #2 on: October 23, 2012, 01:12:30 PM »
Dual Wheels?
If you are Irish would they be Odouls?
Re: Stupid question
« Reply #3 on: October 23, 2012, 01:33:32 PM »
I just see people list for example: 86 sammi, 22re, duels, beadlocks, locked, and linked  What does duels mean?  Are they talking about duel lockers?   Can't be duel exhaust with 22re, and no I don't think they are talking duels on wheels. I don't know either.
Re: Stupid question
« Reply #4 on: October 23, 2012, 09:18:16 PM »
In that case it is dual Transfer Cases, also referred to a doublers.  You can get kits to stack Toyota TC gear boxes together, with two gear boxes depending on gears in the gear boxes you could get up to four different ouputs.
There are way to do the same thing with Suzki TC's, but it is much more involved/harder to do.
Re: Stupid question
« Reply #5 on: October 24, 2012, 08:50:58 AM »
What do you achieve by doing this?
Offline willzila
  • 40
Re: Stupid question
« Reply #6 on: October 24, 2012, 09:06:04 AM »
It gives you tons of gearing options.  Low high, high low, low low high high
Re: Stupid question
« Reply #7 on: October 24, 2012, 04:47:18 PM »
A duel, would be like arranged combat (like a gun fight) between 2 people.
Duals, when talking about an offroad vehicle, probably refers to 2 transfer cases.
Offline fixed blade
  • 361
Re: Stupid question
« Reply #8 on: October 24, 2012, 07:28:25 PM »
Now I have a dumb question.    Why would you want a High low, or a low high?
Re: Stupid question
« Reply #9 on: October 24, 2012, 08:01:42 PM »
Gearing options.
Re: Stupid question
« Reply #10 on: October 25, 2012, 06:46:26 AM »
Gearing options.
You would have highway gears - high, high (same as high range).
You would have back road/off road gears - low, high (same as low range).
You would have crawling gears - low, low (twice as low as low range).
If one of the boxes has a different low range (usually about twice as low) then you would have:
high, high - highway
low, high - back road
high, low (lower set of gears) - crawling
low, low - serious low speed crawling
Because Suzuki Trackers/Kickers have a single gearbox&transfer case (one unit) making duals is difficult.  Also as the gear boxes are stacked together the drive train gets longer and the driveline has to be shortened, increasing the angle it has to run.  When the angle get to much equipment starts breaking.  Two door rigs do not have much space to start with.  Samurai's, LJ's, and SJ's have divorced transfer cases with a short driveline between transmission and TC.  You can see that shortening/eliminating/combining/stacking should all work to get duals.  Toyota TC gear boxes can be bolted together with adapters to stack them in a more ridged reliable manner.
Offline fixed blade
  • 361
Re: Stupid question
« Reply #11 on: October 25, 2012, 07:23:31 AM »
Oh my bad.   I thought it was High rear axle, low front axle.   :laugh:
Re: Stupid question
« Reply #12 on: October 31, 2012, 04:19:54 PM »
That is for mud bogging.  Get that front end spinning twice as fast.  :D
