Suzuki Sidekick, Vitara, Geo Tracker (Gen. 1 Platform) 1989-1998
Problems start and crossing rivers.
eLSanto001
77
Suzuki Grand Vitara 2002
October 25, 2012, 05:34:01 PM »
Greetings, I have two problems with my Geo Tracker 91 (8V) to see if they give me a help:
1. On two occasions not to turn on, taking the battery charger and the gas tank half. When you turn the key the starter turns but does not stop turning.
2. When I am crossing a deep river this low revolutions between 1k and 2k, but leave the river in a few minutes after this returns full force.
Please help me.
eLSanto001
BRD HNTR
2300
56
Re: Problems start and crossing rivers.
October 25, 2012, 09:08:41 PM »
#2 It could be your fan clutch is stuck and doesn't slip, in deep water it then bogs the motor down.
93 Tracker,XL7 springs & 1" raised spring pads in front with YJ springs in back, home built bumpers rear & front (w/winch), 2" x 4" rock tubes, ARB front & rear, converted Sami rear to IFS, 33x12.5x15 aluminum rims, roll cage, 2.7L w/5 speed auto.
talonxracer
1284
34
October 26, 2012, 06:16:03 AM »
I would clean up the connections at the starter and more than likely it requires a rebuild, solenoid sounds like it is sticking when engaged.
If you are gonna play in the water alot, then the engine and electrics need additional waterproofing.
eLSanto001
77
Reply #3 on:
October 27, 2012, 07:35:58 PM »
Thanks for the info
eLSanto001
eLSanto001
77
Reply #4 on:
October 29, 2012, 01:12:38 PM »
Hello, proceeds to clean and fix grounding jeep, then buy a new battery and the tracker is like new.
I still have to try to cross rivers, but this weekend we do a route with my friends and tell them the result.
Thanks again for the info.
eLSanto001
