Where to mount PS reservior?
  • 9 Replies
  • 3652 Views
Offline bbutler455
  • 163
  • 1986 Samurai, 1.6L8V TBI, AC, headers, OME
« on: October 25, 2012, 09:27:06 PM »
Adding the sidekick power steering to my 86 samurai.  Where does the reservior mount to?
Brock
1986 Samurai with Suzuki removable hardtop, 1.6 8V TBI, Vintage Air, OME springs, 235/75 tires
Offline Tan Zuk
  • 562
  • 8
Re: Where to mount PS reservior?
« Reply #1 on: October 26, 2012, 12:16:11 AM »
It is a good idea to keep it as close to the pump as possible. It will also have to be located higher then the PS pump.
Here are a couple examples:
The 1st one is mine it is a TG reservoir made a bracket for it to mount to the fender support and the lower fender well.
2nd may be more what you are looking for.
Offline warbird
  • 110
« Reply #2 on: October 27, 2012, 02:57:21 PM »
Mine, just a 3" shelf bracket...
Offline jcowdin
  • 111
« Reply #3 on: October 27, 2012, 06:36:40 PM »
By using a sidekick setup, do you end up adding a double crank pulley to the run the belt?  And if so, how close to the fan pulley does it get?  Very interested in this setup but do you get any more or less benifits in using a Toyota setup?
The Price is Right!
Offline Tan Zuk
  • 562
  • 8
« Reply #4 on: October 27, 2012, 09:59:37 PM »
Offline rascott
  • 669
  • 15
« Reply #5 on: October 28, 2012, 04:17:50 PM »
i used kick gear.
i got the pulley from trailtough, and it is a little deeper than the stock double-v.
not a problem in my situation(sidekick).
should have done it years ago. i know nothing about toy gear.
i hung the reservoir off the radiator bracket.
« Last Edit: October 28, 2012, 04:22:00 PM by rascott »
« Reply #6 on: October 29, 2012, 06:05:11 AM »
Where did you get the res ( TG ) if you don't mind ?
Offline Tan Zuk
  • 562
  • 8
« Reply #7 on: October 29, 2012, 07:59:09 AM »
http://www.lowrangeoffroad.com/index.php/suzuki/samurai/steering/large-capacity-power-steering-reservoir.html
« Reply #8 on: October 30, 2012, 03:17:04 PM »
Thanks, nice tank for sure.
Offline warbird
  • 110
« Reply #9 on: November 07, 2012, 10:17:56 AM »
Note:  I also run a GM alt so both my belts are 4-rib
