Suzuki Grand Vitara, Vitara, Chevy Tracker (Gen. 2 Platform) 1999-2005
(Moderator:
ebewley
Water leak - passenger side footwell getting wet?!?!
samuraidan
196
speak softly, and carry a big stick
October 30, 2012, 06:16:34 PM »
It's raining like crazy today and when i got into my truck at lunch i noticed the carpet on the floor in front of the passenger seat was a little damp. I assumed i'd left the window cracked but it seemed to be properly shut. Well a few hours later i get in my truck to go home and a little dampness has turned into a small puddle!!!
Does anyone know of any drains that commonly get blocked or plugged?
'00 Vitara 2.0L 5spd w/ Jeff's lift, SR Customs body lift, 5.13's, rear locker, SR Customs steel pinion collar, 1.25" wheel spacers, 15x7, 31x10.5R15 Dynapro MT's.
fordem
4334
170
Re: Water leak - passenger side footwell getting wet?!?!
October 31, 2012, 04:11:30 AM »
Yup - the cowl air intake drains into the wheel arches, if they clog, water collects in the intake and can leak through the fresh air system which is behind the glove box.
samuraidan
196
October 31, 2012, 06:54:26 AM »
Thanks!
Do you know exactly where the drain is in the wheel arches? Have you experienced this type of leak yourself? If so, how'd you go about fixing it?
samuraidan
196
Reply #3 on:
October 31, 2012, 08:04:49 AM »
I THINK i found the problem.
I was poking around and found a small hole in the the cowling right by the base of the passenger side wiper, in it i noticed there was a small rock which in combination with some pine needles was the perfect size to plug the hole.
I removed the rock, so here's hoping the problems fixed! There's another rainfall warning today so i'm sure i'll find out soon enough!
samuraidan
196
Reply #4 on:
October 31, 2012, 10:40:33 AM »
Spoke too soon
Looks like waters still getting in from somewhere?!?!
fordem
4334
170
Reply #5 on:
October 31, 2012, 06:17:22 PM »
Run your garden hose in the cowling vent, if you're not getting water out behind the front wheels, some thing is blocking it - I believe there's a blanking plate under the hood that allows you access.
Junk-Yard-John (03-SWB Vitara)
58
2
Get R Done - You Only Live Once
Reply #6 on:
October 28, 2015, 07:43:33 PM »
heater core leaking? check your coolant level. let me know (+1 for helping you?)
Last Edit: October 29, 2015, 09:11:52 AM by 03 Vitara 2DR (John)
2003 Vitara 2.0L 2DR trail buggy- 31.5"x16" E-rated tyres - Custom 2" suspension lift - 2000Lb SuperWinch
