Transmission Interchangeability Question
  • 2172 Views
Offline jerryp58
  • 449
« on: March 30, 2004, 09:41:05 AM »
Does anyone know if a 3-speed w/OD trans from a '95 Sidekick 4-door 4x4 would fit in my '90 Tracker 2-door 4x4?
Would my ECU be able to handle the OD?
Is a Suzuki 3-speed with OD essentially a 4-speed or is this some kind of electronic OD?
Thanks for any help.
Jerry
Offline TomKat
  • 211
Re: Transmission Interchangeability Question
« Reply #1 on: March 30, 2004, 10:01:47 AM »
There is no "three speed with overdrive" tranny. The three speed has a lockup torque convertor. The four speed has the overdrive gear. A three speed is completely hydro-mechanical except for the lock-up solenoid circuit. The four speed is the one that has a separate computer for shifting.The ECU's are different, I'm sure. It may not work. You will need to positively ID what it is you are looking at. Most likely it's a four speed on a four door.
88.5 Sammy,YJ's,33's,Yota axles,4.9-1 'case,dents and rust...
« Reply #2 on: March 30, 2004, 05:00:48 PM »
Is the 4 speed a  4L30-E trans ???
I was told by a trans guy that the  4L30-E
had an overdrive in the front of the trans ???
Or is the 4 speed in a 4 door not a GM trans ???
Offline idaholwb
  • 772
« Reply #3 on: March 30, 2004, 07:54:46 PM »
 The three speed is a Turbo 180, the four speed is a Toyota, not sure what the model is. You would have to change the wiring and computer in order to make it work.
97 Sport
265/70-16s
2" lift
2.0 swap
Offline zooky
  • 135
« Reply #4 on: March 30, 2004, 08:55:36 PM »
the 4L30E does not come in a tracker/sidekick, it is basically the 3-speed (3L30) with an overdrive bolted on between the bellhousing and the transmission. I am not sure what the tracker/sidekick 4-speed model is
Offline jerryp58
  • 449
« Reply #5 on: March 31, 2004, 11:16:09 AM »
Thanks for the info guys.
There was an eBay auction that listed the 3spd+OD trans from a '95 4-door and that caught my eye.
I know I've read there was a 4 speed available in the four door models (not sure of the trans #), but I thought I read it was too long for the 2 door.
It sold cheap ($75) and I was thinking it might be worth a try, but the electrical/computer issues on top of the mechanical issues kept me away from it.
My trans was having trouble shifting out of 1st gear a while back.  It all started after a simple filter change ::)  But, after a pseudo flush (drain a couple of quarts, refill, repeat, repeat, ...), it's shifting fine again.  I guess I was just thinking it'd be nice to have a spare on hand for the future in case the problem ever comes back.
Anyway, Thanks again.
Jerry
