O2 sensor missing or not???
  • 3499 Views
carl
« on: November 10, 2012, 07:57:57 PM »
I just got my first Samurai, it is an 86 in good shape. Only It does not have an O2 sensor on it. The previous owner put a weber carb on it and hedman header with 2 1/4 pipes. Lift kit.... Do I need to install an O2 sensor?? I am going to have to drop the exhaust system anyway to fix some bad welds... Also there was three bolts missing on the header! I got 22 mpg around town.
Thanks, carl
carl
Re: O2 sensor missing or not???
« Reply #1 on: November 11, 2012, 04:26:37 AM »
I guess the o2 sensor is only needed for fuel injection? Right?
Header bolt..the reason why it is missing is the bolt hole does not line up. Should I pull the header and drill the hole bigger? It does not look like there would be enough play in the other holes to bring it into alignment if I loosened all the bolts . Pretty poor installation, guess the guy got tired of throwing money at it.
Carl
Offline c3006
  • 263
  • 10
« Reply #2 on: November 11, 2012, 05:34:26 AM »
Most aftermarket headers have a hole to put the O2 sensor in and I know the ECM uses it to make decisions about fuel and air to the factory carb. I don't think you need it for a weber as I haven't seen anything on one it could affect. I have put webers on 3 Samis and never used the O2 sensor in the process. Some of the tech guys on here may enlighten both of us on this mater.
Offline talonxracer
  • 1284
« Reply #3 on: November 11, 2012, 06:54:58 AM »
I would remove the header and use a factory exhaust mani gasket as a template to open up the bolt holes required to get a proper fit and make sure the exhaust ports and header runners are perfectly lined up.
Offline Joe Llamahead
  • 209
  • 9
« Reply #4 on: November 11, 2012, 08:07:33 AM »
General info : back in ths era there were "feedback" carburators . They did use a o2 sensor  for on the fly adjustments in most cases these  systems also controlled ignition timing.
If your distribute has a vacume and mechanical advance there is no reason to have an o2 sensor. If it doesn't have the vacuum/mech advance I would find one that does. And completely eliminate the system.
Good advice on the header bolts. I'm going to add that all the bolts should be started and in a few turns before you tighten down any of them. Sorry if you already know this but I just wanted to mention it ...... Just Incase.
carl
« Reply #5 on: November 15, 2012, 08:40:04 PM »
Yep the distributor has the vacuum advance so I am good to go. Any advice on it being hard to start when cold outside. This thing is really cold blooded! It has a manual choke. Once warm it runs great.
