Lift Spacers - How Hard Is It
toyman
6
November 13, 2012, 06:08:56 PM »
Being right near 70, but a pretty good wrench, how hard is it to install Jeffs spacer kit. 94 Sidekick 4 dr.
chadstichter
162
5
98 4door home built coil yota swap 31s rear e-lock
Re: Lift Spacers - How Hard Is It
November 13, 2012, 06:33:39 PM »
its really easy ive done 2 of them and im 15. it helps to drop the front diff and undo the sway bar so the a arms can drop out more to get the springs on and off the front. the rear is really streight forward it helps to undo the brake lines from the frame mounts to. i used the one from lowrangeoffroad.com and cleared 31s i would go with 30s though if i was doing it again
hope this helps
chad
98 4door home built coil yota swap 31s rear e-locker, 8000lb winch and synthetic rope
|...BEER TRUCK..........| ||'|";, ___.
|_..._..._______===|=||_|__|..., ]
l(|removethispart|@) (|removethispart|@) l(|removethispart|@) (|removethispart|@) l(|removethispart|@)
jwarnick11
46
Jeep? you know barbie drives one of those.
November 14, 2012, 05:11:56 PM »
Its not hard at all.. I just installed a set on my 94 door and it wasnt bad at all. the worst part was breaking loose the rusty bolts. So best advise get a can of PB blaster!! Then again I didnt have any airtools which Im sure would have helped a ton..
94 kick 1.6 16v
fully rebuilt motor with custom head work
doug thorley header
jeffs 2in spacer lift
30x9.50 on 15x8 cragers.
toyman
6
Reply #3 on:
November 14, 2012, 06:20:39 PM »
Thanks for the replies, I think I'll try it if I decide to keep it.
