tank saver trailer hitch
  • 2680 Views
carl
« on: November 20, 2012, 10:40:52 AM »
Has anyone turned their tank saver into a trailer hitch??
Carl
Offline willzila
  • 40
Re: tank saver trailer hitch
« Reply #1 on: November 20, 2012, 11:08:27 AM »
I wouldn't think it would be strong enough. The metal is pretty thin. I guess it gets its strength from the shape. Also it really is a "flat" surface so getting a strong weld on it might be tuff
carl
« Reply #2 on: November 20, 2012, 11:58:46 AM »
Mine maybe an after market one, not sure. It is wide and thick. I could add gussets where needed. I'll have to find a stock picture of a tank saver (protector) and take a look. The steel is at least 3/8 inch thick. Welding wont be a problem, that was how i made my living at one time. Guess I'll check some photos here to look at the rear ends...LOL
Offline willzila
  • 40
« Reply #3 on: November 20, 2012, 01:00:47 PM »
Hmm maybe they're different on the 2 and 4 doors. My 2 doors tank save is maybe 1/8 thick sheet steel. And is shaped a beam
Running across with a weird square piece in the middle.
carl
« Reply #4 on: November 20, 2012, 05:02:58 PM »
After checking around on what I got, I guess it is call a steel step plate. It appears that it can receive a trailer hitch. More research...  https://www.hitchsource.com/images/curt/11277/installsheet/CM_11277_INS.PDF
« Reply #5 on: November 21, 2012, 03:05:05 PM »
My brother cut up a hitch from a 90's Dodge half-ton to put on the back.  You can also find bolt on hitches as well but they usually use the smaller hit size.
Offline kreator
  • 634
  • 15
« Reply #6 on: November 22, 2012, 08:32:42 AM »
But also remember that there are only 4 bolts holing that tank guard on , its not like a hitch on a tube bumper.
Offline rfnut
« Reply #7 on: November 22, 2012, 08:48:57 AM »
The PO welded angle iron across the round pipe part of the protector and welded a flat bar hitch to that. It looks good sitting behind my Tracker, but I don't have any plans to use it. No idea of the structural integrity.
