Injector????
  • 1981 Views
Offline Alaska101
  • The Original !! What started it all.
Injector????
« on: March 29, 2004, 11:02:34 AM »
Is there anyway of testing the injector to see if it is working or geting power from the ecu???
My zuki stoped on me a if i pour gas in it it will run so the problem is fuel.
Thanx
1979 Lj81 Truck. Named REP-TAR! (Green thing from the rugrats)
Mod's include:
2001 GV frame w/ 2.0l dohc, and auto trany
Snorkel, 31x10.5 R15 tyres, Soon to be 35's
, also will have a dump box!!
Offline TomKat
  • 211
Re: Injector????
« Reply #1 on: March 29, 2004, 12:07:00 PM »
get a "noid" light at an auto parts store. They're cheap enough. Plugs into the injector connector and flashes to indicate ECU and wiring is working. I have also heard some people use LED's in place of the noid lights. I have never tried this, though.
88.5 Sammy,YJ's,33's,Yota axles,4.9-1 'case,dents and rust...
Re: Injector????
« Reply #2 on: March 29, 2004, 04:46:06 PM »
hot wire the fuel pump, then hit the injector
(quickly) with 12V jumped from the battery,
or if you know how to test with a multi-meter
check if the injector has an Ohm reading, if
it does not, the injector is bad/gone, if it does
have a reading, which it probably does it's the
EFI Computer.
