Sway bar modification
  • 4592 Views
Offline nprecon
  • 2318
  • 52
  • ONWARD... through the fog!
« on: June 02, 2015, 08:21:43 PM »
OK... I figured if my truck had a lift on it, then my sway bar and links would have more constant tension on them.  That's my logic behind this, anyway.  So, I found a piece of square tubing that was about 1 1/2" inch square and 1/4" thick, cut it to length, based on my sway bar mounts, then cut this piece in half, then drilled two matching holes in this tubing to align with the threaded holes in my frame, then mounted my sway bar to these.
These mounts push my sway bar forward and downward.  Do they work?  I guess they do. ???  I installed these in 2007 and they have been on there ever since.  I changed my sway bar links once since then.  I replaced the original OEM links with a new set of Moog links about four years ago.
For what it is worth.
Offline JDMCRX
  • 1110
  • 02 Grand Vitra Pimp lol
Re: Sway bar modification
« Reply #1 on: October 29, 2015, 06:09:36 AM »
The main issue with the GV is the higher the lift your control arms start pushing in and the sway bar is to wide. You need to heat the ends up and bent them in a bit so your end links dont get destroyed or bind up.
01 GRAND VITARA
Offline nprecon
  • 2318
  • 52
« Reply #2 on: May 04, 2016, 06:23:43 PM »
I think that item #5 within this link (from FTS 4X4), performs the same task as the spacer I made 8 years ago.
http://www.fts4x4.com/en/products/?method=detail&aid=72
Offline eLSanto001
  • 77
  • Suzuki Grand Vitara 2002
    • My Channel in Youtube
« Reply #3 on: July 08, 2016, 11:33:15 AM »
HI
Spacers made ​​of an inch and a half in the stands of the stabilizer bar , the terminals were a little inclined but works perfectly . Upload photos later.
eLSanto001
Offline eLSanto001
  • 77
« Reply #4 on: July 18, 2016, 01:27:24 PM »
Hi sorry for the late, here the pictures.
eLSanto001
Offline nprecon
  • 2318
  • 52
« Reply #5 on: July 19, 2016, 09:29:05 AM »
Did your sway bar links install easier than before? Do they now appear to be better aligned with the hub assembly mount?
Offline eLSanto001
  • 77
« Reply #6 on: July 20, 2016, 05:24:13 PM »
Yes no problem  ;D and It not totally aligned, but much better if you install without these spacers  8).
I have seen that other vehicles have rear stabilizer bar and have not seen anything anywhere for GV, have seen something? ??? ??? ??? ???
eLSanto001
