ARB locker with you 4.88 stock gears
  • 16 Replies
  • 6254 Views
Offline captwoody
  • 688
  • ZUKIWORLD Online!
« on: June 03, 2015, 08:25:20 AM »
this is a redo since we lost forum sections. when I first attempted the install I found out the lockers diameter was a bit to large so I had to do the following
ORW machined ID of ring gear to 4.63" and chamfered .015" off locker corner edge of ring gear so ARB would fit tight and bolt up. so if you are an automatic 2.0 99-05 with 4.88 gears this will work for rear only . Other than machining it was a standard install. i will attach linc from another Suzuki forum with additional
Just a Newbie crushing one rock at a time,2x4 rocksliders,lowrange 2"suspension lift 2" body lift and skid plates,5000 winch,towbar,grand vitara rear springs,100watt lights,ARB compressor /air up kit,ARB RD209 LOCKER,Roof rack,tow hitch, General AT2 255/70/15 or 31/10.5/15 Mud tires , 5.12 Gear swap,off road tent trailer,LED Lights
Offline captwoody
  • 688
  • ZUKIWORLD Online!
Offline nprecon
  • 2318
  • 52
  • ONWARD... through the fog!
Re: ARB locker with you 4.88 stock gears
« Reply #2 on: June 03, 2015, 09:15:41 AM »
Thanks captwoody.  That's some of the fine point info that would have been lost and some one would have to reinvent the wheel (again) one day.  Cool beans.
Offline bodeene
  • ZUKIWORLD Online!
« Reply #3 on: July 23, 2015, 08:55:32 AM »
Captwoody. Who modified your ring for this? I'm new to the zuki stuff but would love to put an arb in my zr2 tracker.
Offline captwoody
  • 688
  • ZUKIWORLD Online!
« Reply #4 on: July 23, 2015, 04:46:11 PM »
4 wheel parts Murrieta. if you need 4.88 thats done I have it in a box I went to 5.12 gears when I lifted 2 more inches and added 31" tires just pm me
Offline bodeene
  • ZUKIWORLD Online!
« Reply #5 on: July 24, 2015, 07:51:35 AM »
So if I wanted to go with 31s I'd have go go with 5.12 gearing? I was thinking about adding a 1inch body lift to my 2 inch coil spacers and 1.5 wheel spacers and going with a 225/85/16 to get 31s.
« Reply #6 on: July 24, 2015, 10:18:43 AM »
Suppose you start by telling us what you have now - there were three different engines used in the gen 2 and three or four different gear sets - 5.12s might not be appropriate for your particular build, or, they might just as easily be when you have now.
Offline bodeene
  • ZUKIWORLD Online!
« Reply #7 on: July 24, 2015, 03:00:10 PM »
I have a zr2 v6 4 door I do not know the gearing that is in it. I have a 2 inch coil spacer lift from low range offroad. And 30x9.5 on stock wheels
Offline bodeene
  • ZUKIWORLD Online!
« Reply #8 on: July 24, 2015, 03:12:10 PM »
I fully feel with some wheel spacers and 16inch rims 31s would fit fine with just the coil lift its got plenty of clearance and doesn't rub except at full lock now.
Offline captwoody
  • 688
  • ZUKIWORLD Online!
« Reply #9 on: July 24, 2015, 04:17:59 PM »
I have a 2.0 2dr 4x4 and with the 4.88's  it pulled 31's but was a little bogged down. still would do 85 on freeway just took a bit to get there
« Reply #10 on: July 24, 2015, 05:45:06 PM »
Chock the front wheels to prevent the truck from moving and jack one rear wheel of the ground - mark the drive shaft and the tire that's off the ground and then count the number of times the drive shaft rotates for two full revolutions of the wheel.
If I'm not mistaken, it should be 4.875 if it's an automatic transmission, 4.3 if it's a manual.
5.125 gears will definitely help.
Offline nprecon
  • 2318
  • 52
« Reply #11 on: July 25, 2015, 10:00:47 PM »
Fordem is correct, it came with 4.88 gears.  Whether it would clear 31" pizza cutter tires with the 2" coil spacer lift with the plastic cladding the ZR2 came with... one way to find out.... try one on for size.  I like the pizza cutter tires.
At least you have the V6 engine which generates about 19 more horsepower than the 2 liter engine and the auto tranny.  So some of the gearing loss could be handled with the V6 engine.  The narrower tire would be easier to pull than a full 31X10.5 tires.  The larger tires may cause your tranny to search for the over drive speed though.
Offline bodeene
  • ZUKIWORLD Online!
« Reply #12 on: July 26, 2015, 08:46:39 AM »
I guess I will have to find some 16 rims and try em on for size . The 30x9.5 clear easy and it runs just as good as stock. My gas mileage didn't even get affected but maybe 5-10 miles a tank, which could be my driving. Other wise power is more than fine. I may not worry with 31s we will see in the future. i also cut the mud flap part of the plastic. Flares are still there just not the flap. I'm working on a bumper right now since I can't really find one I like the calmini almost seems to bulky.
Offline nprecon
  • 2318
  • 52
« Reply #13 on: July 26, 2015, 07:02:12 PM »
The only 16" rims I found were the steelies or alloy Grand Vitara rims.  You can find 16" in a lot of aftermarket rims, but I was looking for the rims with 4 1/4" back spacing.  Additionally, not all aftermarket rims clear the calipers on these trucks.
Offline bodeene
  • ZUKIWORLD Online!
« Reply #14 on: July 30, 2015, 03:09:55 AM »
Nprecon thank you for saying that I had us similar issue with a pair of 15s I bought now I know what I need to fit. 4.5 backspace
