Unimog axles under Samurai
  • 14 Replies
  • 5935 Views
Offline camisami88
  • Jeeps? We don't need no steenking Jeeps.
« on: March 29, 2004, 04:44:25 AM »
What I need is the brutal truth.  Can it be done without large amounts of fabrication?  I'm kinda lazy and like wheelin' alot better than wrenching.  One thing I don't like is rolling.  My theory is to put 'Mog axles, that weigh half as much as my Zuk, in as ballast.  Should lower the center of gravity a bit.  Also the 40" tires on 20" wheels is mighty appealing, along with the portal axles for ground clearance help.  I do plan on modifying the body quite a bit to fit that big of tire.  Hopefully it will be legal for sreet use in PA, as this is also my work truck.
The real question is some of the tech, like offset of diffs, rotation direction and such.  If you know of any good 'Mog sites, I'd like to hear about them as well.  Thanks in advance for the help.
Rich
Offline Mike71
  • 1449
Re: Unimog axles under Samurai
« Reply #1 on: March 29, 2004, 05:33:13 AM »
well i cant help u with specifics..but it will take ALOT of wrench time to put mogs on 40" tires under ur sammy...alot of time
plus then u will be more likely to break something (i got big tires syndrome (= )
Offline 1bigtracker
  • 3409
« Reply #2 on: March 29, 2004, 06:58:21 AM »
i have seen mogs handle 48in rubber on a heavy truck and not break.  mabey a drive shaft if it was cheap but never a axle.
stu
« Reply #3 on: March 29, 2004, 07:21:51 AM »
It won't be street legal, but if you want the
details, Jake Palmberg is Da Man   ;)
« Last Edit: March 29, 2004, 07:22:45 AM by wildgoody »
Offline 1bigtracker
  • 3409
« Reply #4 on: March 29, 2004, 07:34:35 AM »
is he running 16.5 rims?  i didn't know you could with mogs.
stu
lucszuk
« Reply #5 on: March 29, 2004, 08:04:00 AM »
that     is     sweet
Offline 92Sidekick4x4
  • 1456
« Reply #6 on: March 29, 2004, 10:12:05 AM »
does jake have like a website??? he owns a off road shop??? i may be wrong, but thats one awsome sammi
lucszuk
« Reply #7 on: March 29, 2004, 11:49:06 AM »
not a sammi its an sj 4 10 :o :o :o
« Last Edit: March 29, 2004, 11:49:16 AM by lucszuk »
Offline 1bigtracker
  • 3409
« Reply #8 on: March 29, 2004, 01:11:52 PM »
its a sammy.  i will bet money on it.
stu
  • 1456
« Reply #9 on: March 29, 2004, 01:14:10 PM »
i think it is a sammi too  ;D
Offline 1bigtracker
  • 3409
« Reply #10 on: March 29, 2004, 01:17:41 PM »
i know its a sammy. ;D
stu
Offline 1bigtracker
  • 3409
« Reply #11 on: March 29, 2004, 01:25:02 PM »
Stock 87 sammy!
sj410 grill
Nissan head lights.
toyota Mr2 1600 16v twin cam motor
toyota corrola 4spd auto
nissan transfercase
samurai transfercase
404 Mog axles, with rear steer, and full hydrolics
cable lockers
19.25 inches dif. clearance
44" boggers, 15x14 beadlock wheels
custom coil suspension
115" wheel base, still on stock swb frame
warn 9500 ti winch
25 gallon fuel cell, relocated inside vehicle
there is a few other things, but otherwise just another Sammy!
Offline 1bigtracker
  • 3409
« Reply #12 on: March 29, 2004, 01:25:30 PM »
haha
stu
lucszuk
« Reply #13 on: March 29, 2004, 02:40:17 PM »
i was wrong.....
wt eva i was high
  • 1456
« Reply #14 on: March 29, 2004, 03:01:16 PM »
stu, where did u get the info? id love to read more about that truck
