Auto transmission install
  • 3324 Views
Offline corsazuki
  • 11
« on: July 07, 2015, 05:35:09 PM »
I have a 88 Samurai that i swapped a 94 1.6, 16V in to with a modded harness and the 1.6 ECU.
I would like to install an automatic trans, is there a difference in ECU
 programs from stick to auto?
What is the best trans to install?
I am looking at the 4 speed Suzuki trans.
« Last Edit: July 13, 2015, 07:03:08 PM by corsazuki »
88 Samurai, 16V EFI, Calimini springs, 10" total lift, on 12.5X33s
Offline fordem
Re: Auto transmission install
« Reply #1 on: July 14, 2015, 05:40:58 AM »
As far as I know the 4 speed auto is electronically shifted, so there will be a transmission controller, and that, again, as far as I know, does communicate with the ECU (something related to throttle position) so I would expect the ECU to be different.
« Last Edit: July 14, 2015, 07:37:17 PM by fordem »
Offline corsazuki
  • 11
« Reply #2 on: July 14, 2015, 06:30:23 PM »
Thanks for the input.
yes the 4 speed is electronically controlled but i wasn't sure if there is a transmission controller or not.
I was hoping someone had done this before and could give a little insight into what I could expect to encounter doing this.
The 3 speed is not electronically controlled but then there is no overdrive for the highway.
Offline fordem
« Reply #3 on: July 14, 2015, 07:46:57 PM »
There is supposedly a Volvo version of that four speed that has no electronics - the Suzuki transmission is the 03-72LE, the Volvo will be an 03-72.
Depending on your reasons for wanting to go with an automatic you should also be able to run the 03-72LE with a manual shifter - it would be like a standard transmission but without a clutch - research the AW4 as used on the Jeeps, and RADesigns shifters - the transmissions are very similar.
Offline corsazuki
  • 11
« Reply #4 on: July 15, 2015, 11:59:13 AM »
Thanks
