vacuum advance
  • 3128 Views
Offline 90Stomper
  • 427
vacuum advance
« on: March 27, 2004, 12:18:37 PM »
90 tracker:  in pulling the motor and testing everything i tested the vacuum on the dis vacuum advance.  it moves just fine but will not hold vacuum.  i asked around and was told that some are suposed to and some are not.  anyone know if my advance unit is good or bad before i spend $68 for a new one, or $145 for a whole rebuild dis? ???
2004 chevy tracker, 4door, V6
says 'Chevy' on the outside,
Re: vacuum advance
« Reply #1 on: March 27, 2004, 03:38:36 PM »
my 89' didn't hold vacuum, so I got one that did
thinking the turbo blew it out, but now the new one
does the same thing  ??? I just live with it.
Offline jerryp58
  • 449
Re: vacuum advance
« Reply #2 on: March 28, 2004, 12:39:02 AM »
I'll try to dig a little deeper, but FWIW, a quick glance at the shop manual test of the vac advance only talked about "smoothness" of motion, not whether it would hold vacuum or not.
Jerry
Offline 90Stomper
  • 427
Re: vacuum advance
« Reply #3 on: March 28, 2004, 02:27:14 AM »
ya, that is why i posted this!  thought that was strange :-/
thanks, guess maybe its normal
Offline alterego158
  • 27
  • Frog is my co-pilot!
Re: vacuum advance
« Reply #4 on: May 08, 2006, 12:56:51 PM »
I have an '89 sidekick and the vacuum advance unit does not hold vacuum.
It also sort of clicks from one position to the next.  Is this the opposite of what's described as "smooth" in the manual or is this acceptable?
Offline alterego158
  • 27
Re: vacuum advance
« Reply #5 on: May 11, 2006, 03:13:34 PM »
I'm an idiot.  It was clicking in time with me pumping the vacuum pump.
Checked out a few vacuum advance units at the junkyard: none of them seemed to hold vacuum.  So that answers that.
Offline darnold87
  • 351
  • 11
Re: vacuum advance
« Reply #6 on: May 11, 2006, 03:35:59 PM »
I'll check mine when I get home.  It's an 89 1600 8-valve in a sami.  All I know is that GM HEI distributors are DEFINITELY made to hold a vaccuum.
~Davey
'94 Suzuki Sidekick JLX
'04 Lexus GX470
