Is this correct? timing 1.6 16valve
  • 3170 Views
Offline RAINMAN69
  • 6
« on: July 25, 2015, 12:05:12 PM »
I'm assuming I goofed somewhere and everything needs done from scratch.
Setting crank to 12
Pulling timing belt off
Setting cam to #4 cylinder valves closed(checked by blowing hose)
Putting belt back on.
Turn two revolutions on crankshaft to relieve tension on belt
Set #1 cylinder to tdc with valves closed(checked by blowing hose)
Checking that rotor is at 1 oclock.If not pulling disty and setting it to 1.
Is this correct?
Offline RAINMAN69
  • 6
Re: Is this correct? timing 1.6 16valve
« Reply #1 on: July 25, 2015, 01:14:26 PM »
Took the belt off tdc on crank
put cam on#4 closed
Offline RAINMAN69
  • 6
« Reply #2 on: July 25, 2015, 04:20:12 PM »
Did everything above and still won't start.Getting fuel and spark.Did a compression test on #1 105 psi my adapter got stuck,so calling it a day for now
Offline ecoast
  • 509
  • 8
    • East Coast Canvas
« Reply #3 on: July 27, 2015, 11:30:28 AM »
Go here and start over:
http://www.fixkick.com/
Sent from my LG-D850 using Tapatalk
Offline zoran.matejcic
« Reply #4 on: August 28, 2015, 11:45:37 AM »
Hi, my name is zoran. I'm from croatia and i have suzuki sj410.
Maybe you have cable of 1st on fourth and so on?
nemojte me shvatiti doslovno;)
Offline ecoast
  • 509
  • 8
    • East Coast Canvas
« Reply #5 on: October 05, 2015, 12:26:29 PM »
Get it going?
