More of a bolt-in front end replacement
  • 19 Replies
  • 4732 Views
Offline explosivo
  • 3157
« on: March 24, 2004, 05:09:56 PM »
Is there any way to just take the front differential out of, say, an XL-7 or Grand Vitara to put in the tracker, or are modifications necessary to get the driveshaft/cv-shafts bolted onto it?
I ask because I would like something more inexpensive than the Anvil, and something less complicated than what is outlined in this article.
omghi2.us[/url]
Offline Kreg
  • 795
    • Island 4x4
Re: More of a bolt-in front end replacement
« Reply #1 on: March 24, 2004, 06:37:55 PM »
Unless you find a smoking deal from a wreckers the front end off of an XL7 will probably cost you close to an anvil anyways. (we'll at least here in BC)
The XL7 axel housing itself will probably bolt in pretty easy, but I think you gotta swap out the gears. (higher on the difficulty scale)
« Reply #2 on: March 24, 2004, 09:15:38 PM »
It will help just replacing the 3rd member with a GV or XL-7 unit. But you will still be stuck with the weak right side half shaft. Many people have trouble with trashing the mount on the Alum. 3rd and the GV/XL-7 replacement would correct this weak point. I'm almost posative that there are frame differences in the GV's and the Kick/Tracker that would not allow you to switch the entire front unit without custom fabricating the mounts.
HTH,
  • 6598
  • 68
« Reply #3 on: March 25, 2004, 12:42:43 AM »
There are these options:
http://www.zukiworld.com/month_090103/feature_sidekickdrivetrainimprovements.htm
Offline explosivo
  • 3157
« Reply #4 on: March 25, 2004, 11:30:46 AM »
Hmm... so how much do each of the following items generally go for?
Hawk Modified Sami Carrier
XL-7 Differential casing
GV Third Member
(The Hawk site isn't much help)
omghi2.us[/url]
Offline zookiemike
  • 474
  • $,reppin Michigan,$
« Reply #5 on: March 25, 2004, 06:34:31 PM »
I think the guy at hawk said that the vitara 3erd member was $250 and the housing was the same. By the way were in mi do you live? The reasin i ask is couse im going to a mud bog in durand on the 17th and id like any one i can get to go.
« Reply #6 on: March 25, 2004, 10:36:14 PM »
HTH,
Nope, straight swop  ;D (well, after you've replaced the gears :()
Offline tonka-toy
  • 154
  • tonka
    • tonka-toy
« Reply #7 on: March 25, 2004, 11:18:20 PM »
i did it on mine
used the complete 2.5 v6 grand vitara steel axle and had the internals removed. then fitted a set of internals from a standard vitara ( well plus lsd in my case ) and bolted it in place.
works a treat
not worried about popping axles anymore ... only shafts that go now .. not as many since the suspension settled on the vitara. now i may of lost a bit of height but the articulation is cooooooooooooool  :D
« Reply #8 on: March 25, 2004, 11:41:18 PM »
Cool, thanks for the information 8)
Offline explosivo
  • 3157
« Reply #9 on: March 26, 2004, 10:50:44 AM »
I live about 50 miles due south of the bridge... between Gaylord and Petoskey... where's Durand?
omghi2.us[/url]
Offline Mike71
  • 1449
« Reply #10 on: March 26, 2004, 02:18:11 PM »
gaylord..thats like a street here in sac..manlove :o
Offline MB
  • 223
« Reply #11 on: March 26, 2004, 02:21:36 PM »
Durand is a little southwest of Flint :)
lucszuk
« Reply #12 on: March 26, 2004, 03:38:19 PM »
go solid front axle man!!!!!!!!!!!!!!!!!!!!!!!!
Offline explosivo
  • 3157
« Reply #13 on: March 26, 2004, 03:43:59 PM »
ah... that's pretty far to drive my little beater, plus I've got no trailer. Otherwise I'd gladly swing by.
About a straight axel swap, that's something I'd love to do. Unfortunately I lack the skill, money, and time to do it. If the Tracker wasn't my daily driver, I'd start on a swap.
omghi2.us[/url]
Offline 1bigtracker
  • 3409
« Reply #14 on: March 26, 2004, 03:46:47 PM »
my tracker isn't a DD eather but i just don't wana do it cuz that takes all the fun out of haveing a IFS rig.
stu
  ÂÂÂÂÂÂÂ
