MAF trouble code 0102
  • 2524 Views
Offline DOWNEASTER
  • 104
« on: August 03, 2015, 07:10:24 PM »
Hello guys I got a 0102 MAF code.before I start work'n on it,i was hope'n one of you guys mite know what else can trip this code if there is such a thing.i did a quick test with a DMM and I got like over 5.64mA on the output wire.But I don't know what specs are.There was a weird thing when I had the DMM on DC volts it red over 12...? i didn't retest that yet,as I been try'n to find the spec mA or volts for the MAF input wire first.WOW I hate wiring...lol.
Re: MAF trouble code 0102
« Reply #1 on: August 04, 2015, 12:57:59 PM »
I would suggest that you download the 96 FSM from ACKsfaq.com. From what I recall the supply to the MAF is 12V.The output is technically in mA but is specified as a voltage at idle.
« Reply #2 on: August 04, 2015, 01:03:33 PM »
Ignition ON engine OFF, output should be 1 - 1.6V, it will need to be connected so back-probe it.
Offline DOWNEASTER
  • 104
« Reply #3 on: August 05, 2015, 03:22:08 AM »
THANK YOU Rhinoman. i plan on tackle'n it today.
Offline DOWNEASTER
  • 104
« Reply #4 on: August 05, 2015, 01:33:46 PM »
Well i got .6 to .7 volts on the output wire .so looks like a new MAF sensor huh.
Offline captwoody
  • 688
« Reply #5 on: August 06, 2015, 10:58:55 AM »
 A can of MAF cleaner at autozone is $8 at  i was under the impression if contacts are clean voltage reading should come up if you have not tried cleaner for 8 bucks not much to lose.i had same codes on my first 2.0 engine and it cleared them
Just a Newbie crushing one rock at a time,2x4 rocksliders,lowrange 2"suspension lift 2" body lift and skid plates,5000 winch,towbar,grand vitara rear springs,100watt lights,ARB compressor /air up kit,ARB RD209 LOCKER,Roof rack,tow hitch, General AT2 255/70/15 or 31/10.5/15 Mud tires , 5.12 Gear swap,off road tent trailer,LED Lights
Offline DOWNEASTER
  • 104
« Reply #6 on: August 06, 2015, 01:57:15 PM »
I forgot about that trick.I'll give it a try and let you know.thanks
