TRACKICK GARAGE SALE!
  • 36 Replies
  • 9486 Views
« on: August 29, 2015, 09:49:14 AM »
All of my Trackick parts hoard up for sale, by part or if someone wants to make an offer on everything and come by and pick it up I am certainly open to that. Smaller stuff shipped, big stuff pick up. SOMEONE MAKE ME AN OFFER ON EVERYTHING AND BRING A TRUCK!  :laugh: There are way too many pics to post so if interested I'll send you a pic of item, just include your email. ALL ITEMS IN VERY GOOD CONDITION, CLEAN AND READY TO INSTALL.
1. Set of used Corbeau sport seats in good condition. Black Fabric, no mounts, drivers seat missing inside ( next to console ) plastic cover. $100
2. Front wheel seal set NIB. $10
3. 13" Grant padded black leather steering wheel with adapter and mounting hardware $30
4. AC control modules $10 ea.
5. Crank Shaft seal saver kit NIB $5
6. 1" Driveshaft spacer $10
7. power steering and water pump pulleys $ 10 for both
8. MAF UNIT and COIL $70 both
9. Extended bump-stop set, new never used with extensions and rubber bump stops $30
10. Stock braced idler arm, NEW. $25
11. Halogen head light bulb set $10
12. NEW front control arm bushing set for both sides front and rear $35
13. NEW Drivers side window regulator $25
14. NEW coolant hose set $25
15. Oil filter sandwich plate with pressure sending unit and AN fittings for pressure gauge or turbo feed $20
16. ECU with mount and all relays for 3 speed auto trans $75
17. Calmini Ceramic coated header and down pipe, includes donuts and NEW gasket $150
18. Trans or PS oil cooler $20
19. 2 Spal electric fans 14" and 6 " both $25
20. winch fairlead and 3/8ths cable 100 ft. $30
21. Trackick front bumper skin, with inside styrofoam block and lower rad plate. VGC $30
22. 16V intake system complete needs cleaning $45
23. 4 cleaned and tested 16V injectors stock, $50
24. Console padded armrest cubby with storage and cup holders ( home made but nice ) $35
25. My spares box, kydex with steel corners. Lockable and strong.
EVERYTHING ON THIS LIST BUT THE WINCH FAIRLEAD AND CABLE, STEERING WHEEL AND ADAPTER, OIL COOLER, BUMPER SKIN, SEATS, INTAKE SYSTEM AND CONSOLE FITS COMFORTABLY IN THIS SPARES BOX AND WEIGHS ABOUT 60 LBS TOTAL. I'LL PACK IT ALL BACK IN AND SHIP THE WHOLE THING TO YOU MAKE OFFER.
26. Remanufactured 16V engine ready to drop in with NEW everything inside, Includes valve cover freshly painted and installed, distributor and new wires, cap and rotor installed, oil pan freshly painted and set up with turbo AN10 oil drain. ( includes AN 10 cap ) installed, dipstick installed, everything needed to finish including gasket set and NGK iridium plugs. Everything to hook it to an auto trans, flywheel and adapter, trans plate, etc, finish gasket set with new exhaust ss steel gasket, manifold gasket, etc. First $1000 takes it.
27. Transfer case with Calmini 4 2 1 crawler gears and twin sticks. Includes interior cabin boot panel and shifter boot. Twin stick shifters with screw on extensions for those with body lifts. First $400 takes it.
28. Stock transfer case with 63K on it. $75
29. 3 buckets of stock take off accessories: PS pump, AC compressor, ALT, intake system etc, Everything $30.
Everything + shipping to your address.
Pics of any and all stuff sent to you at your email upon request. Again, someone willing to take everything and pick up I will make a KILLER DEAL and help you load it! This would be a great way upgrade a tired Trackick. Feel free to share this post too.
Easiest to reach me by text 856-816-4647, please include item info. EVERYTHING LOCATED NJ 20 MINUTES OUTSIDE PHILLY.
« Last Edit: September 06, 2015, 10:47:12 AM by bentparts »
Offline kreator
  • 634
  • 15
Re: TRACKICK GARAGE SALE!
« Reply #1 on: August 29, 2015, 03:34:46 PM »
which engine dose the header fit and would you ship it to me in Salem
« Reply #2 on: August 30, 2015, 07:44:10 AM »
Fits a 1.6 16 Valve Bob and of course I'll ship it. It's not too heavy so it shouldn't be very expensive. Paypal is fine. Give me your zip code and I'll get you a shipping quote if you want.  $29 to your zip Bob.
« Last Edit: August 31, 2015, 05:44:15 PM by bentparts »
« Reply #3 on: August 30, 2015, 07:52:49 AM »
more stuff
« Last Edit: August 31, 2015, 04:44:50 PM by bentparts »
Offline Thirty-Nine
  • 286
    • Subcompact Culture
« Reply #4 on: August 31, 2015, 01:19:34 PM »
Pics of seats?
Offline kreator
  • 634
  • 15
« Reply #5 on: August 31, 2015, 01:34:32 PM »
The shop Zip is 97317
« Reply #6 on: August 31, 2015, 04:31:26 PM »
I just got home from work Bob, I'll get that quote for you tonight. Thirty Nine:
« Reply #7 on: August 31, 2015, 04:33:09 PM »
more seat pics, wear on drivers seat, typical from climbing in and out.
« Reply #8 on: August 31, 2015, 04:35:08 PM »
more stuff
« Reply #9 on: August 31, 2015, 04:44:19 PM »
ECU for 3 speed auto 16V 1.6
« Last Edit: August 31, 2015, 05:31:04 PM by bentparts »
« Reply #10 on: August 31, 2015, 04:46:10 PM »
more stuff
« Reply #11 on: August 31, 2015, 04:49:07 PM »
more stuff
« Reply #12 on: August 31, 2015, 04:49:59 PM »
and more
« Reply #13 on: August 31, 2015, 04:52:26 PM »
and more
« Reply #14 on: August 31, 2015, 04:54:36 PM »
injector set
