Stuck clutch
  • 3038 Views
Offline pgoodman
  • 6
Stuck clutch
« on: October 01, 2015, 06:35:13 AM »
I have a center force clutch in my Samurai.  Well I left it sitting for quite a while and now the clutch will not disengage.   Anyone have a trick to get it unstuck?
I've tried riding the brakes, I pulled it up to a tree and pushed gas and brake pedals while holding the clutch down.
I can't get it to break free!!!    HELP PLEASE!
88.5 Samurai, RRO jeepeater lift with stage II OTT steering, custom 2 in body lift, 16 V EFI, Trail tough 4.9 T-case, 4.62 lockers, chrome moly front axles, rear disc brakes, power steering, 33-12.50 mud grapplers, smitty built winch, custom built front and rear bumpers and tire carrirer.
Offline Joe Llamahead
  • 209
  • 9
Re: Stuck clutch
« Reply #1 on: October 01, 2015, 05:51:05 PM »
The first thing to try is hit the starter with the transfer in gear and the clutch in it could just pop loose.
If no such luck ,
 Then warm it up with the trans in neutral then put it in gear and start it up get it up to 15-20 mph push in the clutch and step on the brake . That should pop it loose. If not you got some wrenching to do .....
Offline fordem
Re: Stuck clutch
« Reply #2 on: October 02, 2015, 06:00:38 AM »
The above methods assume that the clutch release mechanism is functional - maybe that should be checked first.
I've seen the first method used on a number of occasions - back I when the building I worked in was used as a storage bond for newly assembled vehicles - even though the release mechanism would disengage the clutch disk would stick to the flywheel and the vehicle would move.
  • 209
  • 9
Re: Stuck clutch
« Reply #3 on: October 03, 2015, 09:38:12 AM »
Good point fordem .  It's possible that the clutch may mot be releasing . A common problem on hydraulic clutches . And to a much lesser degree cable operated clutches .
Offline Sammy9212
Re: Stuck clutch
« Reply #4 on: October 17, 2015, 11:24:40 AM »
Could try putting the car in second gear while it's not running then start her up, that's what I had to do to free mine. Just make sure there nothing in front of you  ::)
